Results 1 to 12 of 12
    Feb 2006
    I have tried to convert the new Charlie and the Chocolate Factory about 4 times now.
    Everything is fine up til the fixing pts portion. My physical and virtual memory are totally consumed and then I can the ff....exe memory error.
    All my other movies are fine though. Very strange. Here is my log:
    ************************ SYSTEM INFORMATION ************************
    ***************************** VOB2MPG *****************************
    Title:
    Version: 2.1.0.0
    Executable: C:\Program Files\BadgerIT\VOB2MPG\VOB2MPG.exe
    Executable size: 636 KB
    Executable size in bytes: 651264
    Executable CreationTime: 1/16/2006 3:30:20 PM
    Executable LastWriteTime: 1/16/2006 3:30:20 PM
    Executable LastAccessTime: 2/15/2006 6:01:21 PM
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 20.5 GB
    DeviceID: D:
    FileSystem: NTFS
    FreeSpace: 45.5 GB
    ********************* END OF SYSTEM INFORMATION ********************
    ********************** Input Folder *******************
    15:51:43: Volume in drive D is Storage
    15:51:43: Volume Serial Number is F073-4558
    15:51:43: Directory of D:\CHARLIE_CHOCOLATE_FACTORY_D1\VIDEO_TS
    15:51:43: 02/19/2006 02:52 PM <DIR> .
    15:51:43: 02/19/2006 02:52 PM <DIR> ..
    15:51:43: 02/19/2006 02:02 PM 90,112 VTS_01_0.IFO
    15:51:43: 02/19/2006 02:15 PM 6,525,208,576 VTS_01_1.vob
    15:51:43: 2 File(s) 6,525,298,688 bytes
    15:51:43: 2 Dir(s) 48,862,846,976 bytes free
    15:51:43: D:\CHARLIE_CHOCOLATE_FACTORY_D1\VIDEO_TS>
    16:00:09: ffmpeg version CVS, build 3276800, Copyright (c) 2000-2004 Fabrice Bellard
    16:00:09: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
    16:00:09: built on Nov 9 2005 11:51:11, gcc: 3.2.3 (mingw special 20030504-1)
    16:00:09: inputduration4logo: 67
    16:00:09: Input #0, mpeg, from 'D:\CHARLIE_CHOCOLATE_FACTORY_D1\VTS_01.mpg':
    16:00:09: Duration: 01:07:53.4, start: 0.045500, bitrate: 12814 kb/s
    16:00:09: Stream #0.0[0x1e0], 29.97 fps: Video: mpeg2video, yuv420p, 720x480, 7500 kb/s
    16:00:09: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
    16:00:09: Stream #0.2[0x82]: Audio: ac3
    16:00:09: Stream #0.3[0x81]: Audio: ac3
    16:00:09: Assuming NTSC for target.
    16:00:09: Output #0, dvd, to 'D:\CHARLIE_CHOCOLATE_FACTORY_D1\VTS_01-fixedPTS.mpg':
    16:00:09: Stream #0.0, 29.97 fps: Video: mpeg2video, 720x480, q=2-31, 7500 kb/s
    16:00:09: Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
    16:00:09: Stream mapping:
    16:00:09: Stream #0.0 -> #0.0
    16:00:09: Stream #0.1 -> #0.1
    16:00:09: error, non monotone timestamps 1093092 >= 0
    16:00:09: [dvd @ 00415804]buffer underflow
    16:00:09: error, non monotone timestamps 2159160 >= 0
    16:00:13: error, non monotone timestamps 17973074 >= 0
    16:00:13: error, non monotone timestamps 3652795 >= 0
    16:00:14: [dvd @ 00415804]buffer underflow
    -> There are several hundred lines of the same buffer underflow here
    16:00:45: [dvd @ 00415804]buffer underflow
    16:00:45: [dvd @ 00415804]packet too large, ignoring buffer limits to mux it
    -> There are several thousand lines of the same buffer underflow here
    16:39:08: [dvd @ 00415804]buffer underflow
    ********************** Output Folder *******************
    16:43:30: Volume in drive D is Storage
    16:43:30: Volume Serial Number is F073-4558
    16:43:30: Directory of D:\CHARLIE_CHOCOLATE_FACTORY_D1
    16:43:30: 02/19/2006 04:43 PM <DIR> .
    16:43:30: 02/19/2006 04:43 PM <DIR> ..
    16:43:30: 02/19/2006 02:52 PM <DIR> VIDEO_TS
    16:43:30: 02/19/2006 04:43 PM 2,383,902,720 VTS_01.mpg
    16:43:30: 1 File(s) 2,383,902,720 bytes
    16:43:30: 3 Dir(s) 46,478,942,208 bytes free
    16:43:30: D:\CHARLIE_CHOCOLATE_FACTORY_D1>
  2. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    Just an fyi... no flames pls.
    I used DVD Sr in k and it went straight thru no poblems or glitches.
    Feb 2006
    ok. I'll try it.
    Feb 2006
    same problem...
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    How did you get the 6GB vob? DVD Decrypter? What are you intending to do with the mpeg? Reauthor?
    Feb 2006
    I used dvd decrypter and shrink. I want to view on my 360.
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Will the 360 play mpegs? If so have you tried just changing the file extension of the file to .mpg?
    Feb 2006
    It does play them. That's how I found your app on Digg regarding playing them on the 360.
    I tried to rename the extension but the video jumped all over the place.
    I have successfully converted about 10 other movies without a problem.
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Well looking at the log there certainly are problems with the source. Have you tried VOB2MPG on the DVD itself... i.e. leaving out DVD Decrypter et al.?
    Also if there are multi angles that could be screwing things up....
    Feb 2006
    No. I didn't realize I could use it to decrypt the contents.
  11. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Arh - good point! You can't.... Maybe something like anydvd would help....
    Feb 2006
    let me check.
