i have a wmv file that i am trying to encode with tmpegnc but it keeps telling me that is not supported. is there a way to encode this file or do i have to convert it to mpeg or avi before encoding with tmpegnc, if so what program do i need to use to do so.
Results 1 to 9 of 9
no, you encode with super.
if you want to encode with tmpgenc try first increase the directshow reader priority, www.videohelp.com/tmpgenc#problems or use avisynth, https://forum.videohelp.com/viewtopic.php?t=284288 -
You don't really need any most of the time. Drop the WMV into the bottom window. Then at the top #1, select mpg (mpeg ll) if that's what you want.
You can select the audio codec wanted in #3.
You can adjust the video and audio boxes in the middle if needed. It depends what you want to do with the final product.
The lower window will show you the encoding settings. They are easy to change.
Then just go to the bottom and hit 'Encode now'.
Generally if you have a setting wrong, the program will let you know. It's a simple converter. If the results aren't what you want, then TMPGEnc would probably work better.
EDIT: If your final product is to be DVD, then look to the upper left on this page for 'What is' DVD for the DVD format specs. and set your encoder accordingly -
It is encoding now, is there a way i can view the encoding process or not,will it tell me when it is done ?
It should tell you when it's done. There's a indicatior that runs while encoding. It will make several passes. It puts the encoded file back in the source folder.
[FFmpeg] Up encoding speed for wmv's
By Klagar in forum Video ConversionReplies: 5Last Post: 24th Jan 2011, 13:00 -
[FFmpeg] Optimize WMV encoding
By Klagar in forum Video ConversionReplies: 4Last Post: 24th Nov 2010, 09:49 -
wmv encoding, cannot compress audio
By kidcash in forum Newbie / General discussionsReplies: 7Last Post: 27th Jan 2008, 14:58 -
Virtualdub WMV Encoding
By kidcash in forum Newbie / General discussionsReplies: 1Last Post: 18th Jan 2008, 03:47 -
WMV encoding driving me mad
By cutitfine in forum Capturing and VCRReplies: 2Last Post: 27th Dec 2007, 21:39
