hey my tv tuner does not receive sound from my video recorder I am using S-video cabel to connect the tuner and the video recorder. What am
I doing wrong, THANKS
Does your tuner accept an audio input from the recorder? You may have to run the audio output directly to your soundcard and adjust the settings.
I am Jack's medulla oblongata -
You're not connecting the audio, S-video is video only. Use some other cables to connect your audio.Originally Posted by petar one"Art is making something out of nothing and selling it." - Frank Zappa
Check for a seperate audio input (as above) as S-video cable carries video only....still need audio from source...such as left and right RCA component or Digital audio connevtor.
hi guys thanks for your advice it helped me out. But I have another problem with my S-VIDEO cable sometimes it gives me color picture and sometimes black and white .I change the cable and third to change the video formats on the tuner but no result. How do I fix it.
I suspect a bad connection, that's exactly what happens when one line is bad. If you've changed the cable then one of the connectors might be bad.Originally Posted by petar one"Art is making something out of nothing and selling it." - Frank Zappa
TV Tuner for Magnavox DVD Recorder
By gregmlr in forum Capturing and VCRReplies: 32Last Post: 26th Apr 2012, 23:07 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 03:05 -
tuner in DVD recorder
By miki100 in forum Newbie / General discussionsReplies: 7Last Post: 4th Sep 2008, 00:18 -
Best video and sound card with Hauppauge TV Tuner
By nagihcim1 in forum Newbie / General discussionsReplies: 0Last Post: 28th Jul 2008, 09:57 -
DVD Recorder Tuner
By jh76 in forum DVD & Blu-ray RecordersReplies: 10Last Post: 7th May 2008, 14:24
