Hi,
I'm still trying the constant quality. Does anybody else out here use it?
Here is the ffmpegX command I used:
and here is the result (so far):Code:/Applications/video/ffmpegX.app/Contents/MacOS/ffmpegX -psn_0_9830401 /Library/Application Support/ffmpegX/mencoder /Users/me/Desktop/video/video.VOB -ovc x264 -nosound -ni -sws 1 -x264encopts threads=2:me=4:qp_constant=26:i4x4:keyint=120:cabac:deblock:nob_adapt:bframes=1:psnr -ofps 25 -vop scale=704:400,crop=702:576:10:0,pp=0x33,harddup -of rawvideo -o /Users/me/Desktop/video/video.VOB.ff.264
I don't understand how 259kbps could correspond to a qmin of 26 in this case. I know that the first minute of the video is almost entirely black, but that's all. So, at 448.7s, the bitrate should be much higher, shouldn't it?Code:Pos: 448.7s 11219f ( 3%) 3fps Trem:1752min 353mb A-V:0.000 [259:0]
This is what I mentionned in another post. Sometimes the constant quality qmin=26 leads to bitrates like 1900kbps for a video around 700x400, sometimes to what I mention here.
Anyway, I'm gone to wait for this to finish, and then watch the result.
Regards,
I was tempted to just remove my post, because I've been talking too fast, but then I thought it could be usefull to other people.
So, here is the deal: the video ended up with a 400kbps bitrate, but the quality was very good (global PSNR 42). The video was just old, and the sharpeness was quite low, so the encoding was able to achieve a very high compression (10 times), having constant quality and qmin=26 (qmax=standard value).
Ok, so after reading this, I understand that constant quantizer is different than constant quality.
So I would like to know if ffmpegX is going to include this possibility using mencoder or x264 (I still don't really get what's the difference between x264 and mencoder H.264 in the presets)? Is it planed, and if yes, when? If it's not planed, is there a technical reason?
Thanks a lot for any answer
To be more precise, I'm talking about the --crf option of x264. This seems to be real — at least subjectively better — constant quality.
I would be great to have this option in ffmpegX!
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 19:35 -
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 22:28 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40
