This is slightly off-topic, but I was thinking of upgrading my 12" DVI PowerBook's memory. The specifications are DDR266 PC2100 SODIMM. Does this mean that anything above this will also work, e.g. DDR333 PC2700 or DDR400 PC3200, or does it have to exactly the PC2100?
Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh?
No-one?
Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh? -
DDR memory was designed to be backward compatible, but there are no guaranties; the motherboard has to support it. The speed of RAM memory is based on the frontside bus, so for a 133 MHz bus, 266 MHz Double Data Rate memory seems to fit. If higher speed memory works in this Mac, don't expect a performance gain.
Thanks. It's purely a cost thing. The higher speed memory is actually cheaper than the older types. Must be a supply and demand thing.
PC memory
By alintatoc in forum ComputerReplies: 17Last Post: 17th Nov 2009, 17:24 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
Memory
By ProducerHarley in forum ComputerReplies: 1Last Post: 3rd Dec 2008, 00:38 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31
