I have an ASUS TV FM CARD and I want to capture from my VCR to my PC. I connect my VCR to my PC but it looks like that for some reason I can't find the video channel! I press play from my VCR remote control but I can't see the content of my VHS tape in the PC screen...
Please.... Don't use ALL CAPS in your post. It is considered 'shouting' and impolite and will not get you many responses.
Have you looked in this Asus TV Card forum?: http://www.neoseeker.com/forums/index.php?fn=browse_forum&f=5278 -
Sorry... I didn't know... I changed it as you can see! Thanks for your help!
No problem. Did you have any luck finding any answers in the Asus forum?
EDIT: In the case of US VCRs, the video is usually output on channel 3 or 4, if you are using the antenna or cable out. I'm not familiar with that card. If it has a composite input,, you may be able to use the video out from your VCR, along with sending the sound to your sound card.
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 12:32 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 12:54 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)
By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 05:35 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 17:47
