Results 1 to 9 of 9
  1. After converting to VCD mpeg1 with TMPGEnc - my burning software (Adaptec EasyCD) says that it is not a valid file and will not work when burnt to a VCD disc.
  2. Use nero then and it will work Im quite sure
  3. Problem is...
    Nero won't recognise my Samsung CDRW
  4. Hi!
    You tried going to the Ahead website and downloading the latest drivers?
    Also, what version of Nero u using?
    Sue xxx.
  5. Finally got it working!
    Convert non compliant mpeg to avi with RADtools
    Convert avi to compliant mpeg with AVI2MPG
    Create VCD with Easy CD 4
    Don't spend money on upgrading NERO to suit my writer
    Now to learn menus and sound
    Feb 2001
    Palmdale, CA
    better solution and less work, use vcdeasy and you can do chapters also.
    Feb 2001
    Palmdale, CA
    and it's free!
  8. where do we find this vcd easy to download
