Does anyone have the setting for Archos 320 to use with ffmpeg? I have tried numerous with no success. I don't want to use a pc and that software to convert aiv to mpeg4.
From the manual: For the AV3x0, you will need to create an AVI file that is MPEG4 Simple Profile (DivX/XviD) with a resolution of 640x480 or smaller (320x240 will do for the Archos LCD) and a sound track that is stereo MP3 CBR.
So, try on a short clip:
- XviD (mencoder) preset
- XviD (ffmpeg) preset
- DivX (mencoder) preset
- DivX (ffmpeg) preset
At first, only change the Video Size to 320x240, save other options for later experimentation.
At least one of these ought to produce a workable file.
Video files for an Archos AV 500
By merryperson69 in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2009, 07:08 -
Archos 605 Video Encoding
By DJboutit in forum Video ConversionReplies: 4Last Post: 27th Dec 2009, 15:38 -
[Archos 605] transform from 720p.HD.DVDRip.XviD.AC3 to Archos format ?
By birdwing in forum Portable VideoReplies: 2Last Post: 6th Nov 2009, 00:41 -
Archos 404 & DVR stand vs Archos AV 500 - difference in MPEG-4 recordin
By DavidMcGowan in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2007, 06:49 -
Archos for recording TV movies for later conversion into Divx format
By guy1955 in forum Portable VideoReplies: 0Last Post: 23rd Jul 2007, 07:46
