If i convert DixX movies into DVD, what i the filesize ratio i should consider. I want to maintain as much quality while converting to DVD so if i have a DivX movie of roughly 1 GB, how many MB should the resuktant DVD video be?
THERE IS NO RATIO!
If you want as much quality as you can, get a bit-rate calculator and use the run-time to figure out the bit-rate for the encoder! -
Well, forgive me for being so misinformed. How do i use a bitrate calculator? Does the concept of using a bitrate calculator apply on to DVD's and DivX or does it apply to video conversion as a whole?
Aspect Ratio Help! 1.3 vs 1.0 and conversion from .m2t
By Bman. in forum EditingReplies: 9Last Post: 1st Oct 2009, 10:37 -
Changing Aspect Ratio on wmv to divx conversion.
By steve_hawthorn in forum Video ConversionReplies: 7Last Post: 27th Feb 2008, 12:58 -
DV 4:3 to 16:9 aspect ratio conversion
By hysteriah in forum Video ConversionReplies: 6Last Post: 9th Dec 2007, 02:40 -
Divx Certified dvd player won't recognize 16x9 aspect ratio
By maca in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Nov 2007, 12:48 -
Aspect ratio Conversion?
By Colmin in forum Media Center PC / MediaCentersReplies: 4Last Post: 25th Sep 2007, 17:18
