After not using SVCD2DVD for a while, during which time I installed 5 or 6 things, I get
The instruction at "0x1d1c3f31" referenced memory at "0x0834ffa1". The memory could not be "read".
I rebooted the system, and it still did it, so I upgraded to v2.02146 and it still does it.
How would I go about tracking what SVCD2DVD is depending on that
has changed. (I do have VC++ on the machine).
Thanks,
- Lenny Gray -
I would suggest a reinstall of .Net 1.1 and .Net 1.1 SP1 in the first instance to see if that sorts it.
CAn you also reinstall SVCD2DVD now that the framework is updated?
Still has the problem. But, let me give a little more info. I'm on XP Pro, and yon "memory can't be read" doesn't seem to be in an important part of the program, since, if I leave the error message-box open, SVCD2DVD does run and produces good DVD's for all the various inputs I've given it. It's just not aesthetically pleasing to have to let it run that way.
try upgrading to .net version 2, that's the version i used and the program works.
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 03:03 -
DVD Lab Pro Error: "Read data size is over the buffer limit"
By Motinha in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 03:49 -
Read error on "good" DVD discs?
By jerrylynnb in forum RestorationReplies: 12Last Post: 28th Oct 2008, 07:06 -
A must read "sex" story! Guarantee it will reduce your stress!
By moviebuff2 in forum Off topicReplies: 2Last Post: 18th Jan 2008, 15:51 -
SVCD2DVD "hangs" and then locks Vista
By tngin in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 25th Oct 2007, 15:31
