Hi,
I have an avi that is 640 x 480, at 23.97 fps. I want to make it an m2v and burn a DVD. I typically have been using tmpgenc 3.0 xpress for my encoding. From the forums here, I now understand that I need to use the 3:2 pulldown for my framerate, to get it to the 29.97 NTSC standard. What should I do for the PAR?
Generally, I watch stuff on my computer, but occasionally it goes on a TV. Thus, it needs to be NTSC compliant. However, what's most important to me (after that) is to have it look the best that it can on my computer. I'd like for it to fill as much of the screen as possible, but also have it not be squished or stretched, etc. I'm just very confused as to what settings I need to use. Do I make it 740 x 480? or 704 x 480? Do I somehow change the orientation of the picture? etc. Or, perhaps there is a link or a thread I could be led to on this info? I've looked through the guides, but I wasn't able to find anything explicit about this....
Also, the video is currently progressive. Tmpgenc has to sections-- "set source" and "set output". Do I need to make it interlaced when I set the source? Or do I input it as progressive, and when I use the 3:2 pulldown in the output section it telecines it? It would seem to me that I should put in exactly what the movie already is for the "set source" section.... but I'm not quite sure.
Results 1 to 1 of 1
Editing custom frame size video - portrait/vertical VGA - 480 x 640
By PMESKA in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2010, 07:02 -
Wish to convert from .TS to compliant MPEG2
By gabier in forum Video ConversionReplies: 28Last Post: 9th Jul 2008, 04:34 -
720 X 480 NTSC FCP Settings for dvd burns....
By Hawaiian HD Video in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 24th May 2008, 09:13 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 07:49 -
avi (640*480) to dvd (720*480) without black bars....how?
By Mauserman in forum ffmpegX general discussionReplies: 8Last Post: 10th Sep 2007, 13:25
