Hi Guys,
I've been happily converting divx .avi files to Video_TS folders
for burning to DVD for a while now on my Powerbook.
The quality is fantastic I have to say. Much better than Toast 7 can
manage even on the highest settings and quicker too.
So, I just got a new iMac Core Duo.
I installed the divx for Mac install but divx .avi files would not play in
quicktime. A quick search around and I find that there is a beta of
the 'divx for mac for intel' which I install and we're in business.
http://labs.divx.com/node/76
So now quicktime plays divx .avi files perfectly.
I install the latest version of ffmpegx and plug in the settings I usually
use to convert divx .avi to Video_TS and encode.
The result is that the video encodes fine but there is no audio!
On checking the .ac3 file it's obviously incorrect because it's only 56k in size instead of several megs as it should be.
Then begins many many hours of trying to figure out how to get the
audio sorted. (I even ended up to my disgust looking for a Windows utility and found divx2dvd which I have to say does the job perfectly, but I don't want to use windows!!)
I don't know if the problem is with the beta version of divx for Macintel,
or whether it's with ffmpegx on Macintel.
I tried selecting the decode with QuickTime option to see if that would work but no.
Anyone got any ideas to save me from M$ Windoze?
Cheers,
Kudos
Well I'd just like to thank everyone for the overwhelming response !!
OK, I used Quicktime to convert the divx .avi into a .dv stream. I then
used ffmpegx to convert the .dv into a Video_TS and the video and audio was fine.
So why does ffmpegx fail to directly transcode a divx .avi file into a Video_TS folder on a MacIntel platform???
any one got any ideas....
i've had some problems with it too, with audio and the tools also, but i think some of the stuff doesn't work because ffmpegx isn't a universal binary yet.
Intel R Display audio driver error.
By skorpinok in forum ComputerReplies: 0Last Post: 16th Dec 2011, 07:01 -
Digitizing family VHS movies - interlacing/quality issues on iMac 27"
By genkiness in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2010, 22:32 -
Intel Core 2 Duo T7500 2.20 vs. Intel Core 2 Duo E8400 3.0
By vatkat234 in forum ComputerReplies: 6Last Post: 27th May 2009, 10:42 -
Intel Q6600 Kentsfield or Intel E8400 Wolfdale??? Help me decide which one
By budz in forum ComputerReplies: 33Last Post: 12th Mar 2009, 00:19 -
?Intel chip problem? Video not opening / iMac computer
By migseder in forum MacReplies: 4Last Post: 10th Sep 2007, 00:25
