I'm converting an anime series from .avi to mpeg2. I'm using Tmpgenc Plus 2.5. I had 5 episodes that were giving me problems. The .avi's were 23 minutes each but when converted to .m2v were shortened to only 12 minutes each. I tried playing the files with Powerdvd and Nero Showtime just to make sure. Somehow a big chunk between the beginning and the end is being cut out. I opened the files with Vdubmod and all 5 files show an improper VBR audio encoding and prompts me to rewrite the header. I did so on all 5 files and reencoded them. 3 of them converted just fine. However, the remaining 2 still only play for 12 minutes. I ran the error check through Vdubmod on the original .avi's and it reported: 0 frames masked (0 frames bad, 0 frames good but unendecodable.) I extracted only the video stream with Vdubmod and tried converting it using tmgpe and had the same problem of only playing 12 minutes. I tried using CCE SP 2.7 to convert the .avi and for some reason the file plays for 19 minutes in Nero Showtime but only 12 minutes in Powerdvd. I don't know what else to try. Any thoughts?
Closed Thread
continue in your first topic.
https://forum.videohelp.com/viewtopic.php?t=293153&highlight=
reply to add more information.
Problem converting jpegs to m2v
By PirateAhoy in forum Authoring (DVD)Replies: 0Last Post: 22nd Apr 2012, 15:57 -
Strange audio glitch when converting from avi to mpeg for DVD.
By silmarallion in forum Video ConversionReplies: 3Last Post: 6th Nov 2009, 09:24 -
synching m2v and wav audio - strange problem
By ecc in forum EditingReplies: 7Last Post: 20th Feb 2008, 06:22 -
Strange problem converting local show to mpeg2.
By jcm0320 in forum Capturing and VCRReplies: 1Last Post: 7th Aug 2007, 01:15 -
Strange problem converting Xvid AVI to MPG2
By joelore in forum Video ConversionReplies: 18Last Post: 2nd Jun 2007, 00:40
