On every blank DVD disks that I have, it says 2 hours of play, but when trying to get the best resolution with NERO, it only gives me 1 hour. If I try to add more content, it says that the quality will degrade.
Any way around this, or should I just change program? If I should change programs, what would you recommend (that's not too expensive).
At best quality full frame DVD compliance, one hour will fill a DVDR disc. Anything over an hour will degrade, it is up to you to decide if the level of degradation is acceptable. Most people find that the degradation isn't unacceptable until you go beyond 2 hours on a disc which is why disc manufacturers put 2 hours on the packaging. It means absolutely nothing but it looks good.
Originally Posted by Richard_G
One quick question, speaking of degraded; I've backed up my DVD movies using a program called DVD X Copy because my originals were starting to have noticeable scratches.
If a movie is almost 2 hours, then it had to have been degraded to fit on the blank disk, right? But Besides the fact that there’s no menus and that I only got one language per disk, I do not see any degradation.
So what’s up with that? -
Time on a DVD depends on bitrate,if the video doesn't have alot of motion you can go as low as 4,000kbps@352x480.You can also use MPEG/AC3 audio and reduce the audio bitrate so you can use a higher video bitrate.
The one hour setting is at the max video bitrate(~9,000kbps) and PCM audio,the best way is to experiment with a DVD/RW. -
Originally Posted by MOVIEGEEK
I thought DVDs were like CDs, once converter to TIME, quality didn't matter. An MP3 at 192 bit rate would take the same amount of minutes on a CD as an MP3 at 360 bit rate. Doesn't the same rule appeal to a DVD? -
Audio CD's convert any source bitrate to WAV,so time of play=size on disc.If you make an MP3 CD then bitrate=size on disc.
With DVD-Video:bitrate=size on disc. -
What movieGeek is saying is... The DVD standard is a bit LAXER than the CD standard. CD Standard is 16-bit PCM. That's it.
DVD is quite a bit more flexible, and thus, even though standard is fixed at MPEG2, the bitrate of the MPEG2 CAN vary, and thus, size physical size of the file can vary, even though the play time stays the same. Further monkey wrench to throw in... different types of audio.
So to answer your question, no, the rule does NOT apply to DVD. The bitrate for DVD compliant MPEG is variable, not fixed like CD Audio.
So I'm Making a Power Hour DVD...
By Jskot311 in forum Newbie / General discussionsReplies: 2Last Post: 1st Apr 2011, 13:35 -
DVD Power Hour Project Help.
By GlockMasta in forum Authoring (DVD)Replies: 3Last Post: 1st May 2009, 06:23 -
why convert a MKV to DVD format took more than an hour ?
By c1steady in forum Video ConversionReplies: 2Last Post: 1st Apr 2009, 19:34 -
burning 1 hour of raw footage onto DVD
By sfischer in forum Authoring (DVD)Replies: 2Last Post: 8th Feb 2008, 20:28 -
4 half hour eps on one dvd?
By motleycool in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jun 2007, 23:18
