  1. I'm attempting to backup Twin Peaks (disk 4) and so far DVD Decrypter and DVD Shrink can't seem to handle it. So I finally managed to copy the contents to a folder using DVD Fab, however Shrink still can't read the file structure and Decrypter does'nt have an option to open folders. So what I'm hoping to do is mount the video_ts folder as a drive so that Decrypter will recognize it and I can crack the protection. Anyone know if this is possible? Or is there another way I can solve this problem?
    The odd thing is I did'nt have this problem on the first 3 Twin Peaks disks, just the last one.
    rip with dvdfab decrypter.
    try fixvts if dvdshrink still can't read the file structure.
    Feb 2004
    Australia
    Iso image :
    Create folder .. add audio_ts folder , add video_ts folder in here .
    Video_ts has all the content .
    Use folder2iso to generate iso image of folder .
    Go to www.softpedia.com , visit windows section , then over to right , cd/dvd emulation ... look for the sheep .
    Install it , them you will have a new drive with a sheep icon on it , right click it , choose mount image , locate the iso image that folder2iso created .
    See how you go ...
    There is also one designed by ms , not sure of the link to it , but it is not as freindly as the free one's available at the above mentioned site ... the ms one is a pain but work's fine .. already tested it .
