i have just bought LCD TV " LA40M51B" it samsung and i play my dvd trough Pioneer with component port and my movie is not full screen is like playing widescreen in normal tv
i heard that if you play widescreen dvd on lcd tv or plasma you will get fullscreen picture
Ps. i sorry if i post in wrong forum
Are you playing it with a standalone DVD player? What model? You would have to look in the instructions for your player. The player and LCD should play in the same format as the DVD is made for. The LCD can't convert widescreen to full screen. The format is set by the DVD. Does the picture look normal? Not stretched or shrunk down?
Only if the DVD is 16:9 (1.77:1 aspect).
Many movies are 2.35:1 aspect.
Are you saying it fills the screen horizontally?
Many HDTV or DVD players have a zoom function that fits vertically and chops off the sides.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Did you reconfigure your DVD player to let it know you are using a 16:9 television?Originally Posted by p&p
Somewhere in the DVD player setup menu is a place to set it to output for 16:9 (yours) or 4:3 TV sets, or for widescreen (yours) or fullscreen TV sets. If you haven't changed it already, that's probably the reason, as most are set by default to output for 4:3 TV sets. You might even try reading the manual that comes with the player.
And as others before have mentioned, many movies are wider than 16:9 (2.35:1 movies, for example) and are meant to have some black bars, even on 16:9 TV sets. -
Even on a correctly working 16x9 TV, this is what is happening.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43 -
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 20:40 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36
