    Jan 2006
    South Africa
    Can anyone please help. I have been using DVD Shrink for the past few months without any problems, basically copying any DVD. I tried to copy The longest yard yesterday, but it gives an error message during the analysing phase, I suppose it must be copy protected. I tried to use DVD Decrypter, and this is my problem: When I open Decrypter, there is no source file in the window and it says, “please select a file”. I browsed, went to My Computer, then to my D drive, it opened the Video and Audio TS files. When I click on Video TS, it opens the subfolders, but then I am stuck. Any advice please? I cannot select it all or get it in the Source area of DVD Decrypter. Any advice please? I have subsequently tried 2 other DVDs and both says please select a file in the source area.
    So my questions: 1. Is The longest yard copy protected and how do I get around it?
    2. What mistake do I make with DVD Decrypter
  2. 1. Probably. Use DVDFab Decrypter
    2. Sounds as though DVD Decrypter is in "ISO Write" mode. Go to tools and select either "File", "IFO" or "ISO Read" mode. Otherwise, make sure that the correct DVD drive is selected.
    Jan 2006
    South Africa
    Thanks a lot. I will try it
