can anyone reccomend a prog that will normalize a wav file, convert it to mono and then encode it to vbr mp3 using lame codec?
Results 1 to 10 of 10
If you want the next step up look at SoundForge.
http://www.sonymediasoftware.com/products/soundforgefamily.aspRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Well if it can use any cli encoder, then it must let you do custom command lines.
Free download anyway so you really have nothing to loose by trying.
Reccomendation for the Panasonic AG-1980?
By sunsetandgower in forum RestorationReplies: 19Last Post: 3rd May 2010, 16:12 -
i need a burner app reccomendation
By ChokeUntilDead in forum Newbie / General discussionsReplies: 5Last Post: 25th Aug 2009, 20:22 -
Reccomendation for Purchasing an LCD-TV
By therock003 in forum Newbie / General discussionsReplies: 5Last Post: 26th Mar 2009, 16:00
