Can someone explain how to use TMPGenc correctly to cut an mpeg2 file. It doesn't seem to want to do it. Failing this, if someone can recommend a freeware tool that actually works and is not limited to 7 seconds unless you pay and register or the like , I would be grateful![]()
Results 1 to 10 of 10
Just follow the instructions here...
http://www.vcdhelp.com/tmpgencedit.htm
It is very easy just read carefully and do what is says...
Lata,
Joey -
Sorry man that one sucks use this its a step by step Guide...This is what I used..
http://www.vcdhelp.com/DVDConversionGuide/?id=dvdtovcd3b.html#TMPGEnc
lata,
Joey -
Cheers I'll try this other one... I was just cursing because I'd done everything perfectly and it still wasn't having any of it. It would only let me access the first 10 seconds. Never had a problem using it on VCD though...
I dont believe this!!! That bloody program destroyed my file... I've already lost 70Mb file from Morpheus tonight, now I've lost a 1 gig file from TMPGenc
and to top this all. My file that I backed up didn't resume in Morpheus. It vanished this time. Oh well one and a half gigs down the drain.
I know it is a dvd conversion guide..But when you encode just load the template that you want and you got it and just follow the rest it ain't that hard..
Lata,
Joey -
Dude, thanks for that, the problem is I'm familiar with the usual routine. On this occaision however I didn't get to splice the file into small enough pieces prior to it fully encoding. Rather than starting again, there is surely a quicker way of simply cutiing it in half...
No Problem..I don't mind helping others as long as people answer my posts..I hope that helps you..
Lata,
Joey
Problems Cutting MPEG video in VIRTUALDUB
By Rudyard in forum EditingReplies: 2Last Post: 30th Sep 2010, 21:25 -
New experimental TS cutting software for MPEG-2 and H.264 Transport Streams
By Nukster in forum EditingReplies: 2Last Post: 14th May 2009, 09:16 -
cutting an MPEG
By php111 in forum EditingReplies: 3Last Post: 7th Jan 2008, 08:32 -
WMV cutting-joining-playback problems
By Cusem in forum EditingReplies: 2Last Post: 7th Dec 2007, 03:48 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10
