I've got an avi file that I'm importing to Vegas, but I wanted to add hardsubs and do some preprocessing, so I used AviSynth, made a script, and saved the avs. I tested the avs in VDubMod's script editor, and it all seemed to work.
Here's the AviSynth script:
AVISource("D:\handhc1orig.avi")
LoadPlugin("C:\program files\AMVapp\AVisynth Filters\VSFilter.dll")
TextSub("D:\handhc1orig.srt")
ConvertToYV12()
deen("a3d",4)
Tweak(sat=1.25)
ColorYUV(gain_u=15)
ConvertToRGB32()
Then I used ffdshow's makeAVIS function to put the avs in an avi wrapper. All still seemed to be fine. However, when I open the new avi in Vegas 5, I only get a 4 minute video with not visual or info, instead of the full length 23 odd minutes. There's no audio because it's demuxed.
Does anyone have any thoughts on this?
I decided to frameserve because I currently don't have enough GBs to save all the uncompressed huffuv's of the files at once-- I have to import a section to Vegas, edit it, export it as huffyuv, do post-processing/cleaning, and then compress it to m2v to make room for the next section. I'm editing 4 video's together to make a movie. etc. etc.
If someone has some other options, I might be go for that, but if I can, I'd like to do this with AviSynth.
Thanks.
Hi,
Unfortunately, all the links on that page are old. I've thought of using VFAPI before, but I've never been able to find the readAVS.dll anywhere. I searched here, google, etc. doom9, etc. I'm sure it must be somewhere, but I can't seem to find it....
I'm sure I'm just being blind. But does anyone have an active link to this tool?
http://www.avisynth.org/warpenterprises/I've never been able to find the readAVS.dll anywhere.
under "Other stuff" ... -
YOU are the bomb! Sweet. This should infinitely increase the speed of the whole process. !! Thank you so much. (now, just hoping that it all works as it should...... )
Frameserving from Sony Vegas into MXF format
By 24fps in forum Video ConversionReplies: 5Last Post: 8th Feb 2012, 08:57 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 17:12 -
colors shift when frameserving from Vegas
By crisciunas in forum Video ConversionReplies: 7Last Post: 16th Oct 2009, 16:24 -
Sony Vegas Crashes Using FFDShow Encoder
By send2nik in forum Video ConversionReplies: 2Last Post: 30th Aug 2009, 10:12 -
vegas/ffdshow/avidemux: avc-mp4 encoding for playback in Flash player
By mindplay.dk in forum Video ConversionReplies: 21Last Post: 1st Jun 2008, 17:01
