you know any tv capture software where in you can change the audio source in capturing tv shows? i need a software that can change the audio source of my recording to LINE-IN of my sound card. i have Cyberlink PowerVCRII that im using and has this feature but if you can suggest other alternative that has this particular feature ill will be most happy to try it. Audio source selected to LINE-IN thats the only way i can make my old conexant tv capture card work and i hope ill have other software other than the old PowerVCRII which is no longer supported by cyberlink. i still don't have a budget for buying a new capture card so im still stuck with my old conexant capture card with my old powervcrII
