I have a .ts file that has two sound channels, and want to convert it to DVD.
How do I get a dvd with two audio channles?
I convert it with Nero Vision, but it put the first audio channel only.
Demultiplex the .ts file with projectx or pvastrumento, cut with mpeg2schnitt or cuttermaran (if necessary) and author with a prgram that supports multiple audio streams. Freeware (without menu): ifoedit, muxman; Freeware with menu: dvdauthorgui or gui for dvdauthor; commercial: dvdlab (pro)
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Thanks borax.
What I did was:
1. using HDTVtoMPEG2 to cut.
2. demultiplexing with pvastrumento to one video file + two audio files.
3. authoring with dvdlab pro.
Do you know a more professional menu creating app? -
When I said more professional app, I meant an app that creates more fancy menus. Like of original movies DVDs.
You can create 'fancy menus' like of original movies DVDs with dvdlab pro (and even with GfD). But it needs creativity, time and knowledge how to do it. There is no 'one click' solution for 'fancy menus'
GUI for dvdauthor:
Files Transport Stream, .ts and players DVD/BluRay... possible?
By vygger in forum DVD & Blu-ray PlayersReplies: 8Last Post: 15th Jan 2012, 14:45 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 05:40 -
Playing ".pvr" transport stream files in MPC
By uart in forum Software PlayingReplies: 1Last Post: 7th Jul 2010, 19:26 -
HDTV transport stream to DVD with Avisynth
By sambat in forum DVB / IPTVReplies: 4Last Post: 29th Nov 2008, 19:35 -
need MPEG2 Transport stream and Program stream profiler
By afarun in forum ProgrammingReplies: 3Last Post: 23rd Aug 2007, 02:06
