I'm on the verge of buying a new, high end Sony DV camcorder that has an A to D pass-thru for analog video. I'm also on the verge of dumping my VIVO graphics card due to reliability issues. The graphics card uses an ATI Theater Rage chip and produces analog video captures that are very detailed in both resolution and color. Could I expect the same level of analog capture quality from the camcorder pass-thru, or should I stick with my graphics card? (I know there are many other options, but I'm only interested in the above for now) Thanks!![]()
Usually long gone and forgotten
i use a canon dv camera and yes its very good althou i tend to capture onto dv tape then pass to my pc using the firewire connection
whats that your reading hope its work (s**t caught again) -
DV camcoder "pass through" capture is very good with one major caveat for NTSC capture (other than Japan) and that is the incorrect black level (7.5 IRE goes to level 32 instead of 16 as it should). There is no problem for PAL areas.Originally Posted by TheFamilyMan
see
http://pro.jvc.com/pro/attributes/prodv/clips/blacksetup/JVC_DEMO.swf
The level can be adjusted using an analog procamp (before A/D) or in software after capture.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
With camcorder pass-thru, you get the same quality as your analog video source.
I was using Sony DV camcorder for the same purpose (to backup my VHS tapes), before I bought a DVD recorder. -
Thanks for all the feedback, especially the info about the black level settings. If all goes well, I'll have a new camcorder, and can ditch my flaky graphics card and not worry about getting another VIVO model to replace it.
Usually long gone and forgotten -
I finally got that new camcorder, a sony HC-96. It was tough decision, but for a casual "point and shoot" the affordable 3CCD models just didn't cut it in the low light department. Anyways, its analog passthru basically sucks and is far worse than using my new capture card. It's grainy and washed out. The black setup seems OK for the blacks do look very black (there is no setting for it). I also got a Kworld cheapie capture card ($30) at Fry's that uses the conexant chipset. Its capture quality is excellent once you figure out how to it coax into working with your own tools (ditch the crappy software that comes with it), it's as good as my failing ATI's VIVO.
I will do the same as above. Buy a DVD recorder for VCR transfer, and then pick the miniDV you really like.Originally Posted by Jeremiah58
Need Suggestions for a good Camcorder with great sound quality
By techspark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 8th Apr 2011, 12:34 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
a good MiniDv pass-through camcorder? with s-video??
By adameep in forum Capturing and VCRReplies: 3Last Post: 10th Sep 2010, 14:38 -
Under $150 camcorder with good image quality
By Delta223 in forum Newbie / General discussionsReplies: 6Last Post: 1st Mar 2010, 14:16 -
NTSC IRE levels and DV camcorder Pass-Through capture.
By edDV in forum Capturing and VCRReplies: 84Last Post: 1st Jun 2008, 17:58
