Results 1 to 10 of 10
  1. Hi
    I want to convert some divx & vcds to 3gp, i am wondering which one program gives top quality
    its for nokia 6680
    USA
    I've been impressed with SUPER, and it's freeware.
  3. It isnt working for me man.
    iam trying to convert some divx/mpg files but it gives me error.
  4. did the same thing to me the first time...just check all the different things that the error box point to...after I did that it worked lika a charm..
  5. Member lantern's Avatar
    Oct 2003
    Behind the dark matter
    http://www.w3exchange.com/forumdisplay.php?f=29
    This is a forum specifically for SUPER. You may be able to find some answers there.
    Melde Melda Vessë
    Eruanna ar Eruntano Melda Eruntanohini
    "May your days be bright and contact with stupid people limited."
  6. Try 3gp video converter. Choose the profile that best suits your phone (usually general QCIF 15fps).
    https://www.videohelp.com/tools?tool=3GP_Converter
    Cheers, Jim
    My DVDLab Guides
    Apr 2006
    I have a BenQ S700 cellphone and I downloaded a smallscreenflix movie, it was 64kb formatted Mp4, file size was 8MB. The BenQ video conversion software took the file and made it a 35MB!! file. What's going on here....crazy!
    Natively it doesn't seem to want to play the file, causes the cell phone to lock up.
    man!
    -BigMAc
  8. Here's the settings I use, for great quality.
    Adjust framerate to match the input.
    Cheers, Jim
    My DVDLab Guides
  9. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    I use Nokia Multimedia Converter (Freeware). Never tried Super, may give it a try.
    Quicktime Pro also has the ability to convert to 3GP, but the downside is its payware.
  10. You could also try SPAM, which is also freeware.
    You are in breach of the forum rules and are being issued with a formal warning. It's not free and DON'T DIG UP OLD TOPICS. BYE! BYE!
    / Moderator Baldrick
