Just like title says need install manual for advc 50. Picked one up cheap on ebay but instructions would be nice.
I don't remember getting an installation manual when I got my ADVC-50, but hopefully this helps:
There are two ways to install an ADVC-50 (I see it has been removed from the Canopus site
Firstly, you need to have a firewire card on your PC (or firewire socket on your PC's motherboard).
The first way, it can sit in a CD/DVD drive bay (if it came with the drive bay adapter, see picture below) and attach a white power connector to the rear of the ADVC-50.
Then, attach a firewire cable from the ADVC50's front firewire socket (4pin) or the rear (6pin) to the firewire card socket. I have mine set up like this and the firewire 4pin end is attached to the front, going to the firewire card, thus:
Alternatively, the second way or if you don't have the drive bay adapter, it can sit in a PCI slot (without a power connector as it draws power from the PCI slot) with a firewire cable connected to the firewire socket as described above.
There is no software to install as it will just be considered an external capture device.
After that, attach the cables from your playback device using either composite video or s-video cables and the audio cable.
I hope that this is helpful.Cole -
Even my ADVC-100 only came with a 4 page or so manual. But here's a link to some info about the ADVC-50:
http://dv411.com/advc50.html
Or go to Canopus, register your ADVC-50 and download a manual. They're not particular, even with the wrong serial number and a purchase date from 2004 and from a dealer like newegg.com, as the warranty would have been expired anyhow
The .pdf manual is about 6 pages.
http://www.canopus.com/support/registerproduct.php
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Capturing with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2009, 22:55 -
Canopus ADVC-55 vs. ADVC-110
By bcags7 in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2008, 16:15 -
Should I install Canopus Codec?
By tranbuimd in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 19:01
