I want to make VCD, SVCD, and DVD with ffmpeg
there are many different settinsg for the same thing, like VCD ffmpeg, vcd mpeg2enc...
which one of these do I use?
Results 1 to 13 of 13
Different methods may lead to very similar results. The ffmpeg engine is faster, the mpeg2enc engine produces more compatible output, bitrate-wise. There is no 'best', only one that you'll like better than the other. And you will have to make that choice, based on your personal needs. Just like the various options that are available to each engine, but some not available to both.
For VCD and SVCD, the how-to pages suggest mpeg2enc, if that helps you decide.
Does the AVI play well in QuickTime Player? I believe ffmpegX defaults to decoding with QuickTime, which only works well if your source file plays okay in QuickTime Player. You may need to install additional QT components (codecs) for QuickTime decoding to work.
What does the Summary tab say on the left (the source file information)?
from ffmpeg it saysOriginally Posted by Case
FROM AVI
VIDEO mpeg4, yuvp, 720x480
Audio mp3, 44100 hz, stereo. 192 kbs
Why cant I make this a DVD/VCD or SVCD?
How long until it failed? Right way, or after a long time encoding?Originally Posted by edubz
Thank you, that's very helpful for starters. You didn't answer my first question, tho'.Originally Posted by edubz
My guess at this time is a decoding (reading) error. ffmpegX has several methods of decoding a source file. If you can't get one method to work properly, then use another method.Originally Posted by edubz
Try this: Drop your source file on the ffmpegX. Select the VCD (mpeg2enc) preset. Use the Play button in the upper right. If it plays okay (use ESC to quit mplayer), then you opt for mplayer decoding, which you can set in the Options tab (lower left). Now go to the video tab, look at the frame rate. Only if it says NTSC FILM, then also tick "Set 3:2" in the Options tab. Now you're ready to encode. How is the result?
the avi doesnt play in quicktime, but it does play in ffmpeg and in videolan.
now, I just tried to encode my AVI file to DVD using the mpeg2enc and it said it was finished, but when I try to open it in quicktime, it says its not a file quicktime under stands...
also, I notice a couple of files on my desktop
myFILE.avi.ff.mpeg
myFILE.avi.ff.ac3
and a folder myFILE.avi.ff.dvd
a) installing the DivX codec would help QuickTime understand this kind of AVIs. And then decoding with Quicktime in ffmpegX is a good option as well.Originally Posted by edubz
b) if it plays in ffmpegX, then decoding with mplayer will be a good option.
c) if it plays in VLC, it means nothing, because ffmpegX doesn't communicate with VLC when reading a file.
Just as expected. QuickTime doesn't read DVD files. But Apple DVD Player does. More on that later.Originally Posted by edubz
Temporary files, except for the folder! Inside the folder myFILE.avi.ff.dvd should be a VIDEO_TS folder. Open Apple DVD Player, then File > Open, then locate that VIDEO_TS folder. Preview your new DVD now.Originally Posted by edubz
I installed the divx codec and xvid codec and all I get is a white screen when I try to play it through quicktime...
tried to play through the apple dvd player... nothing, black silence.
just tried to encode got this erorr
Encoding started on Sun Feb 19 19:17:41 EST 2006
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
movtoy4m
Copyright 2002-2005 Johan Lindstr??m
All rights reserved. Used in ffmpegX under license.
INFO: [yuvscaler] input: frame size: 352x240 pixels (126720 bytes)
INFO: [yuvscaler] input: frame rate: 30000/1001 fps (~29.970030)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 352x240, take 352x240+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 352x240, 352x240 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 29.970 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 352x240 pixels (126720 bytes)
INFO: [yuvscaler] output: frame rate: 30000/1001 fps (~29.970030)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] VCD default options selected
INFO: [mpeg2enc] Selecting VCD output profile
INFO: [mpeg2enc] Assuming norm NTSC
INFO: [mpeg2enc] Encoding MPEG-1 video to /Users/edubz/Desktop/SF Documentary.avi.ff.m1v
INFO: [mpeg2enc] Horizontal size: 352 pel
INFO: [mpeg2enc] Vertical size: 240 pel
INFO: [mpeg2enc] Aspect ratio code: 12 = 1:1.1250 (4:3 NTSC for 720x480/352x240 images)
INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO)
INFO: [mpeg2enc] Bitrate: 1151 KBit/s
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 230 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] mpeg1 - setting intra_dc_precision = 0
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 104145!
INFO: [mpeg2enc] Guesstimated final muxed size = 600270486
Computing levels...
SF Documentary.av --% done, ETA --:--:-- (batch 0% done, ETA 99:14:08)
SF Documentary.av 1% done, ETA 00:00:00 (batch 1% done, ETA 00:00:00)
SF Documentary.av 2% done, ETA 00:00:00 (batch 2% done, ETA 00:00:00)
SF Documentary.av 3% done, ETA 00:00:00 (batch 3% done, ETA 00:00:00)
SF Documentary.av 4% done, ETA 00:00:00 (batch 4% done, ETA 00:00:00)
SF Documentary.av 5% done, ETA 00:00:00 (batch 5% done, ETA 00:00:00)
SF Documentary.av 6% done, ETA 00:00:00 (batch 6% done, ETA 00:00:00)
SF Documentary.av 7% done, ETA 00:00:00 (batch 7% done, ETA 00:00:00)
SF Documentary.av 8% done, ETA 00:00:00 (batch 8% done, ETA 00:00:00)
SF Documentary.av 9% done, ETA 00:00:00 (batch 9% done, ETA 00:00:00)
SF Documentary.av 10% done, ETA 00:00:00 (batch 10% done, ETA 00:00:00)
SF Documentary.av 11% done, ETA 00:00:00 (batch 11% done, ETA 00:00:00)
SF Documentary.av 12% done, ETA 00:00:00 (batch 12% done, ETA 00:00:00)
SF Documentary.av 13% done, ETA 00:00:00 (batch 13% done, ETA 00:00:00)
SF Documentary.av 14% done, ETA 00:00:00 (batch 14% done, ETA 00:00:00)
SF Documentary.av 15% done, ETA 00:00:00 (batch 15% done, ETA 00:00:00)
SF Documentary.av 16% done, ETA 00:00:00 (batch 16% done, ETA 00:00:00)
SF Documentary.av 17% done, ETA 00:00:00 (batch 17% done, ETA 00:00:00)
SF Documentary.av 18% done, ETA 00:00:00 (batch 18% done, ETA 00:00:00)
SF Documentary.av 19% done, ETA 00:00:00 (batch 19% done, ETA 00:00:00)
SF Documentary.av 20% done, ETA 00:00:00 (batch 20% done, ETA 00:00:00)
SF Documentary.av 21% done, ETA 00:00:00 (batch 21% done, ETA 00:00:00)
SF Documentary.av 22% done, ETA 00:00:00 (batch 22% done, ETA 00:00:00)
SF Documentary.av 23% done, ETA 00:00:00 (batch 23% done, ETA 00:00:00)
SF Documentary.av 24% done, ETA 00:00:00 (batch 24% done, ETA 00:00:00)
SF Documentary.av 25% done, ETA 00:00:00 (batch 25% done, ETA 00:00:00)
SF Documentary.av 26% done, ETA 00:00:00 (batch 26% done, ETA 00:00:00)
SF Documentary.av 27% done, ETA 00:00:00 (batch 27% done, ETA 00:00:00)
SF Documentary.av 28% done, ETA 00:00:00 (batch 28% done, ETA 00:00:00)
SF Documentary.av 29% done, ETA 00:00:00 (batch 29% done, ETA 00:00:00)
SF Documentary.av 30% done, ETA 00:00:00 (batch 30% done, ETA 00:00:00)
SF Documentary.av 31% done, ETA 00:00:00 (batch 31% done, ETA 00:00:00)
SF Documentary.av 32% done, ETA 00:00:00 (batch 32% done, ETA 00:00:00)
SF Documentary.av 33% done, ETA 00:00:00 (batch 33% done, ETA 00:00:00)
SF Documentary.av 34% done, ETA 00:00:00 (batch 34% done, ETA 00:00:00)
SF Documentary.av 35% done, ETA 00:00:00 (batch 35% done, ETA 00:00:00)
SF Documentary.av 36% done, ETA 00:00:00 (batch 36% done, ETA 00:00:00)
SF Documentary.av 37% done, ETA 00:00:00 (batch 37% done, ETA 00:00:00)
SF Documentary.av 38% done, ETA 00:00:00 (batch 38% done, ETA 00:00:00)
SF Documentary.av 39% done, ETA 00:00:00 (batch 39% done, ETA 00:00:00)
SF Documentary.av 40% done, ETA 00:00:00 (batch 40% done, ETA 00:00:00)
SF Documentary.av 41% done, ETA 00:00:00 (batch 41% done, ETA 00:00:00)
SF Documentary.av 42% done, ETA 00:00:00 (batch 42% done, ETA 00:00:00)
SF Documentary.av 43% done, ETA 00:00:00 (batch 43% done, ETA 00:00:00)
SF Documentary.av 44% done, ETA 00:00:00 (batch 44% done, ETA 00:00:00)
SF Documentary.av 45% done, ETA 00:00:00 (batch 45% done, ETA 00:00:00)
SF Documentary.av 46% done, ETA 00:00:00 (batch 46% done, ETA 00:00:00)
SF Documentary.av 47% done, ETA 00:00:00 (batch 47% done, ETA 00:00:00)
SF Documentary.av 48% done, ETA 00:00:00 (batch 48% done, ETA 00:00:00)
SF Documentary.av 49% done, ETA 00:00:00 (batch 49% done, ETA 00:00:00)
SF Documentary.av 50% done, ETA 00:00:00 (batch 50% done, ETA 00:00:00)
SF Documentary.av 51% done, ETA 00:00:00 (batch 51% done, ETA 00:00:00)
SF Documentary.av 52% done, ETA 00:00:00 (batch 52% done, ETA 00:00:00)
SF Documentary.av 53% done, ETA 00:00:00 (batch 53% done, ETA 00:00:00)
SF Documentary.av 54% done, ETA 00:00:00 (batch 54% done, ETA 00:00:00)
SF Documentary.av 55% done, ETA 00:00:00 (batch 55% done, ETA 00:00:00)
SF Documentary.av 56% done, ETA 00:00:00 (batch 56% done, ETA 00:00:00)
SF Documentary.av 57% done, ETA 00:00:00 (batch 57% done, ETA 00:00:00)
SF Documentary.av 58% done, ETA 00:00:00 (batch 58% done, ETA 00:00:00)
SF Documentary.av 59% done, ETA 00:00:00 (batch 59% done, ETA 00:00:00)
SF Documentary.av 60% done, ETA 00:00:00 (batch 60% done, ETA 00:00:00)
SF Documentary.av 61% done, ETA 00:00:00 (batch 61% done, ETA 00:00:00)
SF Documentary.av 62% done, ETA 00:00:00 (batch 62% done, ETA 00:00:00)
SF Documentary.av 63% done, ETA 00:00:00 (batch 63% done, ETA 00:00:00)
SF Documentary.av 64% done, ETA 00:00:00 (batch 64% done, ETA 00:00:00)
SF Documentary.av 65% done, ETA 00:00:00 (batch 65% done, ETA 00:00:00)
SF Documentary.av 66% done, ETA 00:00:00 (batch 66% done, ETA 00:00:00)
SF Documentary.av 67% done, ETA 00:00:00 (batch 67% done, ETA 00:00:00)
SF Documentary.av 68% done, ETA 00:00:00 (batch 68% done, ETA 00:00:00)
SF Documentary.av 69% done, ETA 00:00:00 (batch 69% done, ETA 00:00:00)
SF Documentary.av 70% done, ETA 00:00:00 (batch 70% done, ETA 00:00:00)
SF Documentary.av 71% done, ETA 00:00:00 (batch 71% done, ETA 00:00:00)
SF Documentary.av 72% done, ETA 00:00:00 (batch 72% done, ETA 00:00:00)
SF Documentary.av 73% done, ETA 00:00:00 (batch 73% done, ETA 00:00:00)
SF Documentary.av 74% done, ETA 00:00:00 (batch 74% done, ETA 00:00:00)
SF Documentary.av 75% done, ETA 00:00:00 (batch 75% done, ETA 00:00:00)
SF Documentary.av 76% done, ETA 00:00:00 (batch 76% done, ETA 00:00:00)
SF Documentary.av 77% done, ETA 00:00:00 (batch 77% done, ETA 00:00:00)
SF Documentary.av 78% done, ETA 00:00:00 (batch 78% done, ETA 00:00:00)
SF Documentary.av 79% done, ETA 00:00:00 (batch 79% done, ETA 00:00:00)
SF Documentary.av 80% done, ETA 00:00:00 (batch 80% done, ETA 00:00:00)
SF Documentary.av 81% done, ETA 00:00:00 (batch 81% done, ETA 00:00:00)
SF Documentary.av 82% done, ETA 00:00:00 (batch 82% done, ETA 00:00:00)
SF Documentary.av 83% done, ETA 00:00:00 (batch 83% done, ETA 00:00:00)
SF Documentary.av 84% done, ETA 00:00:00 (batch 84% done, ETA 00:00:00)
SF Documentary.av 85% done, ETA 00:00:00 (batch 85% done, ETA 00:00:00)
SF Documentary.av 86% done, ETA 00:00:00 (batch 86% done, ETA 00:00:00)
SF Documentary.av 87% done, ETA 00:00:00 (batch 87% done, ETA 00:00:00)
SF Documentary.av 88% done, ETA 00:00:00 (batch 88% done, ETA 00:00:00)
SF Documentary.av 89% done, ETA 00:00:00 (batch 89% done, ETA 00:00:00)
SF Documentary.av 90% done, ETA 00:00:00 (batch 90% done, ETA 00:00:00)
SF Documentary.av 91% done, ETA 00:00:00 (batch 91% done, ETA 00:00:00)
SF Documentary.av 92% done, ETA 00:00:00 (batch 92% done, ETA 00:00:00)
SF Documentary.av 93% done, ETA 00:00:00 (batch 93% done, ETA 00:00:00)
SF Documentary.av 94% done, ETA 00:00:00 (batch 94% done, ETA 00:00:00)
SF Documentary.av 95% done, ETA 00:00:00 (batch 95% done, ETA 00:00:00)
SF Documentary.av 96% done, ETA 00:00:00 (batch 96% done, ETA 00:00:00)
SF Documentary.av 97% done, ETA 00:00:00 (batch 97% done, ETA 00:00:00)
SF Documentary.av 98% done, ETA 00:00:00 (batch 98% done, ETA 00:00:00)
SF Documentary.av 99% done, ETA 00:00:00 (batch 99% done, ETA 00:00:00)
SF Documentary.av 100% done, ETA 00:00:00 (batch 100% done, ETA 00:00:00)
File /Users/edubz/Desktop/SF Documentary.avi.ff.wav has zero power, ignoring...
ffmpeg version CVS, build 3277056, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX static build for ffmpegX
configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
built on Dec 1 2005 03:50:24, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
Input #0, wav, from '/Users/edubz/Desktop/SF Documentary.avi.ff.wav':
Duration: 00:00:30.8, start: 0.000000, bitrate: 1411 kb/s
Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, 1411 kb/s
Output #0, mp2, to '/Users/edubz/Desktop/SF Documentary.avi.ff.mp2':
Stream #0.0: Audio: mp2, 44100 Hz, stereo, 224 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
size= 536kB time=19.6 bitrate= 224.0kbits/s
size= 842kB time=30.8 bitrate= 224.0kbits/s
video:0kB audio:842kB global headers:0kB muxing overhead 0.000000%
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/edubz/Desktop/SF Documentary.avi.ff.m1v looks like an MPEG Video stream.
INFO: [mplex] File /Users/edubz/Desktop/SF Documentary.avi.ff.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 1 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting VCD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/edubz/Desktop/SF Documentary.avi.ff.m1v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 352
INFO: [mplex] Frame height : 240
INFO: [mplex] Aspect ratio : 1:1.1250 (4:3 NTSC for 720x480/352x240 images)
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 1152000 bits/sec
INFO: [mplex] Vbv buffer size : 40960 bytes
INFO: [mplex] CSPF : 1
INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/edubz/Desktop/SF Documentary.avi.ff.mp2)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 44100 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 1 original
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 1403296
INFO: [mplex] target data-rate specified : 1411200
INFO: [mplex] Setting specified specified data rate: 1411200
INFO: [mplex] Run-in Sectors = 18 Video delay = 21600 Audio delay = 24603
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 47104 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Padding : sector=00000000
++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c0!
INFO: [mplex] STREAM c0 completed @ frame 1177.
INFO: [mplex] Scanned to end AU 104144
INFO: [mplex] STREAM e0 completed @ frame 104144.
INFO: [mplex] Multiplex completion at SCR=312717600.
INFO: [mplex] Video e0: buf= 2122 frame=104144 sector=00067909
INFO: [mplex] Audio c0: buf= 4096 frame=001177 sector=00000379
INFO: [mplex] Padding : sector=00192278
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 156141137 bytes
INFO: [mplex] Sequence headers: 6943
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 104144
INFO: [mplex] No. Groups : 6943
INFO: [mplex] No. I Frames : 6943 avg. size 1363 bytes
INFO: [mplex] No. P Frames : 27773 avg. size 1509 bytes
INFO: [mplex] No. B Frames : 69429 avg. size 1509 bytes
INFO: [mplex] Average bit-rate : 359200 bits/sec
INFO: [mplex] Peak bit-rate : 336800 bits/sec
INFO: [mplex] BUFFERING min 1194 Buf max 4326
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 861626 bytes.
INFO: [mplex] Syncwords : 1179
INFO: [mplex] Frames : 674 padded
INFO: [mplex] Frames : 505 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 744
INFO: [mplex] MUX STATUS: no under-runs detected.
(Super) VideoCD xml description created successfully as `/Users/edubz/Desktop/SF.xml'
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
**ERROR: could not stat() file `/Users/edubz/Desktop/SF': No such file or directory
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Documentary.avi.xml'
**ERROR: could not stat() file `Documentary.avi': No such file or directory
++ WARN:
++ WARN:
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Documentary.avi.ff-1.mpg.xml'
**ERROR: could not stat() file `Documentary.avi.ff-1.mpg': No such file or directory
++ WARN:
++ WARN:
++ WARN:
++ WARN:
(Super) VideoCD xml description created successfully as `Documentary.avi.ff.mpv.xml'
**ERROR: could not stat() file `Documentary.avi.ff.mpv': No such file or directory
++ WARN:
++ WARN:
Encoding completed on Sun Feb 19 22:24:13 EST 2006
Remove the space from the filename; the Unix tools think the filename ends where the space is. That's what's causing the error.Originally Posted by edubz
That's odd. But the main thing is mplayer did a good job as alternative.Originally Posted by edubz
You did press play, I presume? The software player may need a signal to get started with harddisk content, unlike reading from media (or disc images).Originally Posted by edubz
How many files in the VIDEO_TS folder? Should be 5 at least.
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 22:15 -
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 04:11 -
FFmpeg changes Target format settings after dropping a new Source file
By GvdB in forum ffmpegX general discussionReplies: 1Last Post: 2nd Sep 2008, 11:59 -
commandline ffmpeg & x264 settings for Ipod 5.5
By halsboss in forum Video ConversionReplies: 4Last Post: 8th May 2008, 22:10 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
