i guess i lost the synch when i converted the video to mpeg-2
i think there was a lot of error frames that got deleted hence the problem.
yeah, i need to erase or delay the audio a bit to make it synch again... how do i do that? im very noob at this so please speak in the lamest terms thanks
Depends on what kind of audio format. You can use the freeware Audacity with a WAV audio format and add some silence, but you need to know exactly how much. Goldwave should be able to do this also, or most any audio editor.
You can take out the audio as a WAV with VirtualDub Mod. How to do:https://forum.videohelp.com/viewtopic.php?t=280779. Then you mux it back in with a program like TMPGEnc. This would be a lot easier to do in AVI format, then VDM could do it all.
Recording 1080i 60 fields/sec vs 1080p 30 frames/sec
By johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2011, 07:38 -
Fix .mov where A/V in sync at beginning, ~1 sec offset at end?
By Grahamf in forum ffmpegX general discussionReplies: 3Last Post: 30th Mar 2011, 13:14 -
I pop in my dvd's, it starts to play, the video/audio lags
By rko2164 in forum ComputerReplies: 5Last Post: 11th Jan 2010, 21:53 -
Sync audio starts-ok but near end 1 sec lag H.264/MPEG-4 AVC AAC LC
By JoeBolden in forum Video ConversionReplies: 6Last Post: 7th Jan 2010, 15:31 -
Audio Damaged After Video Conversion. How to Fix?
By Fluoresce in forum AudioReplies: 1Last Post: 5th Aug 2008, 04:01
