    Feb 2006
    my audio does not match the video how do i fix and in virtualdub how do i open the audio compress its in gray and i cant open
    USA
    Select 'Full Processing. and it will appear. As far as fixing it, you can mux it out or save it out as a WAV. Fixing it depends on what the sync error is. If it's the same offset throughout the video, change the offset. If it gradually gets worse, shorten or lengthen the audio or the video.
    What kind of audio and video are we talking about? Check it with Gspot.
    Feb 2006
    sweet got it to work all i had to do was install lame3 ty
