  1. I use dvd shrink it goes through the first procsess but after I re-author it and do backup it comes up with an error message cannot read disk
  2. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    So you are getting that error from the dvdr after it has been burned and you try to play it ?
    And what drive is giving that error, a drive on your pc or a standalone ?
  3. no ok i use dvd shrink ok I open disc it does that 3 minute scan thing then I re author it to the movie only like I always do then when Iclick backup it comes up with the message
  4. Banned
    Jun 2004
    Okay,
    Try ripping it to a temp folfer on your hard drive first with DVD Decrypter or DVDFab Decrypter.
    Then open the files on your HDD in shrink & not from the disc in the drive.
    I know i did that title ripping with DVD Decrypter & then using shrink.
