Anyone know what the difference is (comparing the results) between DVDx and XMpeg when using the same plugin codec ?
Assume I use CinemaCraftEncoder 2.62 in both programs for the same movie...which one gives the best results or if it's the same, which one is really the fastest ?
Or are there important differences in settings ?
I'm used to XMpeg and if one of the many versions doesn't work, only then start using DVDx. Is this a good choice or should I prefer DVDx above XMpeg/FlasK ??
Greetz
Mars-L
well difrence betwwen them is that DVDx has it own built in Encoder and doesnt need plugins but you can put some and Xmpeg depends on plugin to work properply.....well i perffer Xmpeg over DVDx to use with a plugin becuase i noticed that when i encode wit any plugin with DVDx i hear cracks in the audio soo i suggest you go with Xmpeg
I've heard about the audio problem, but luckily I don't have that problem (with CCE 2.62 plugin).
But if there's no difference I also keep going on with XMpeg
Thanx
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 01:53 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 08:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 14:17 -
Xmpeg help!
By tonydotigr in forum DVD RippingReplies: 6Last Post: 18th Jun 2007, 07:32
