Results 1 to 11 of 11
  1. Member dynamix1's Avatar
    Feb 2003
    Atlanta Ga
    I want to back up a dvd after recoding its at 4800mb. Not relizing i tried to click burn and it says that it wont fit on a a single layer and to remove some of the extras and sound. The sound and extras consist of only 11mb. I used nero recode and then tried dvd shrink. Any ideas on this.
    I reject your reality
    and substitute my own.
    - Adam Savage -
    - Mythbusters -
  2. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    I am surprised that DVD Shrink did not work, as I have used it several times for stuff like this. I don't recode or reauthor just open as files then do the backup like I would for disk.
    Aug 2005
    AKL, NZ
    You mention the sound and extras being only 11Mb, this seems very low, as most AC3 sound tracks exceed 300 Mb for a normal movie..DTS is even more if its included. I think your app is asking for the removal of sound tracks that are not needed...otherwise you will need to re encode the main movie video section with a lower average bit rate to make if fit.
  4. Member dynamix1's Avatar
    Feb 2003
    Atlanta Ga
    that was my mistake it shows dolby digital 2 ch at 337mb, if i remove that there will no audio on the dvd is that correct
    - Adam Savage -
    - Mythbusters -
  5. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    why didnt shrink work, was there an error
    Aug 2005
    AKL, NZ
    You are correct, if you only have one sound track showing then you can not
    delete it. You must re encode you main movie to reduce the size of the video section. DVD shrink should give you options to reduce to the size required,
    Nero Recode should too for that matter. I can not be 100% sure as its been along time since using those apps.
  7. Member dynamix1's Avatar
    Feb 2003
    Atlanta Ga
    under dvd shrink i get the error says that it is too big and make sure automatic compression is on (which it is)
    - Adam Savage -
    - Mythbusters -
  8. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    First,
    Are you ripping it to your hard drive first or just opening the disc in shrink ?
    Second,
    What is the title of the dvd ?
  9. Mod Neophyte redwudz's Avatar
    USA
    Just leave AC3 5.1 and dump all the rest. Your player will convert it to stereo if you don't have a 5.1 decoder.
  10. Member dynamix1's Avatar
    Feb 2003
    Atlanta Ga
    to noahtuck I ripping to my hd. used dvd decrypter
    to redwudz there is no option for 5.1 just 2ch english
    - Adam Savage -
    - Mythbusters -
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I have seen this error when the disc was not decrypted, just copied. Shrink then cannot open the video to actually shrink it. I would rip it again, perhaps with DVD Fab Decrypter, and see how you go.
    Read my blog here.
