On the TMPGEnc, I can't get the video source to load..... .d2v can not open or unsupported. Please help
Don't post the same thing twice! wait till someone answers.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Download the VFAPI plugin from The TMPGenc website and then refer to Sefy's newbie ripping guides on the left. It tells you in the problems section at the bottom how to make sure that this is installed correctly.
1) Delete your entire TMPGENC folder
2) Download: TMPGENC / VFP PLUGIN / DVD2AVI
3) Unzip all into the SAME folder (e.g: D:\TMPGENC )
4) Run the TMPGEncVFP batch file.
5) Recreate D2V/WAV files
This WILL work!
Best Regards,
Sefy Levy,
The TMPGenc VFP Plugin can be downloaded at TMPGenc website. http://www.tmpgenc.com/e_enq.html
_________________
S t e v e D V D
"Happy New Year!"
<font size=-1>[ This Message was edited by: SteveDVD on 2001-12-31 07:56:19 ]</font> -
Had this problem with loading mpg files captures with my ATI 8500dv card. It worked great before, but I had to reload winxp from scratch and all my apps. After the reinstall of win-xp, tmpgenc would load my captures mpg files with the error everyone is getting here. I loaded masses of codes, no help, installed and followed advice here from others, no help. So then I thought, what had I installed before the xp reinstall that wasnt installed yet. It was "uleads movie factory trial" software. The free demo trial from ulead's web. Then in the movie factory setting, I selected it to use mpeg2 and uleads mpeg2 filter. Anyway, tmpgenc started loading my caprtured mpg files as before with no error. I dont know what or how but movie factory set something right!
Had this problem with loading mpg files captures with my ATI 8500dv card. It worked great before, but I had to reload winxp from scratch and all my apps. After the reinstall of win-xp, tmpgenc would not load my captures mpg files with the error everyone is getting here. I loaded masses of codes, no help, installed and followed advice here from others, no help. So then I thought, what had I installed before the xp reinstall that wasnt installed yet. It was "uleads movie factory trial" software. The free demo trial from ulead's web. Then in the movie factory setting, I selected it to use mpeg2 and uleads mpeg2 filter. Anyway, tmpgenc started loading my caprtured mpg files as before with no error. I dont know what or how but movie factory set something right!
