people, i have a slight problem.. i just burned a DVD9 on my DVDLab Pro writin module, and thru Nero 7. to check the DVD-Video, i got together 4 DVD players of different makes, namely -
1) Philips,
2) Philips again,
3) Sony and
4) Thomson.
Now the problem is that my DVD9 is not playing at all on the Thomson player. I am getting an error, which says defective or bad disc after some time. One of the Philips dude is not even reading it. but, the other Philips player, and even the Sony player are giving me a crisp playback. what can the problem be? Has it got anything to do except compatibility issues? pls help me out here guys!
An eye for an eye makes the whole world blind - Mahatma Gandhi
What media did you use ?
Neither of those products are recommended for burning dual layer discs. Search the forums for many discussions on better ways to burn DL media.
DL media compatability amongst players is hit and miss depending on the age of the model.Read my blog here.
isnt Nero 7 good enough for burning DL media? otherwise which software should i use? DVDLab pro said that even CopyToDvd is god enough.. and as far as the media i was using is concerned, it was some shoddy media! thats what i wanted to ask, if it would have been a media problem, then it shouldnt have played on the other DVD players. the philips player should have shown me an error..so i am ruling out the media issue.. its the compatibility of DL with other players that i am worried about..
An eye for an eye makes the whole world blind - Mahatma Gandhi -
Verbatim MKM - anything else it currently hit and miss. I would use good media before stating it isn't the cause.
As for burning software, top of the list would be Record Now Max 7.3 (version ?), DVD Decrypter/ImgBurn. Nero would be low on the list as it creates it's own layer break, regardless of where you might have put it, and is generally considered only competent at best for single layer burning.
Compatability issues may still be the base cause, but if you use crap media then you aren't really giving the players much of an opportunity in the first place.Read my blog here.
hmmm.. i get you..hey thanks dude..
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 11:37 -
Technika DVDFAW08 Multiregion Code and XVid Compatibility Issues
By delta925 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 4th Dec 2009, 13:40 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 19:17 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 20:34 -
Compatibility issues
By boing in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2007, 13:05
