i have recently encoded a couple of avi files (using nero vision)
that are 23.976 fps.
would you expect to notice a very slight "pausing" when there isnt much activity on screen?
im guessing that approx 1 frame per second needs to be used twice to make up 25 fps? or is it the method of encoding causing this?
thanx for any advice.
jonx2
Results 1 to 9 of 9
PAL just speeds 24fps up 4% to play at 25fps. Audio goes slightly "Donald Duck" unless pitch converted.
http://www.kiva.org/about -
It depends how it is converted. Some converters add extra frames to bring the frame rate up, which does lead to jerkiness. As you haven't put a location in your profile, I have no idea where you are from, however most PAL players can play back NTSC material. I never convert to PAL. I encode at 23.976 with 2:3 pulldown and playback as NTSC. This avoids all the inherent conversion issues.
Read my blog here.
so the juttery image im seeing is caused by the encoding then?
its only slightly noticable,maybe im being too picky.
i will try some other software to see what happens.
cheers
jonx2 -
1. Where are you?*Originally Posted by jonx2
2. How are you playing this video? What is the display?
* I assumed your reference to 25fps put you in a PAL territory.Recommends: Kiva.org - Loans that change lives.
sorry for the lack of info.
im uk based so use PAL.
i guess nero 7 uses the add frame process as theres a definite "pause" in playback,i was one of the many who's vegas stopped loading avi files after a re format,so i started using nero as simpler method of converting and authoring.
slightly off topic now,but ive downloaded the trial of vegas 6.0d
which has reported the fixing of allowing mp3 audio,well im afraid my avi files still have "cannot determine stream..." on both video and audio.
i can sort the video with the fourcc changer but the audio isnt recognised.
im know trialing tmpgenc.
cheers
jonx -
You're better off encoding it as NTSC, as I understand most DVD players in PAL land will play it back and convert it on the fly no problem. Try it.
"Art is making something out of nothing and selling it." - Frank Zappa -
thank you,i used nero 7 as before but authered as NTSC,no jitter on playback,strange that PAL is closer to the 23.976 fps but caused the worst playback?
cheers
jonx -
loading the 23,967 avi in virtualdubmod
stream/streamlist and when the source mp3 is,
full processing (right click) and no compression (right click on the stream in streamlist) en save wave
then you click on disable in the steamlist box en return to the main box of vdm
video/direkt stream copy
video/framerate /change framerate to 25
file/save as
now you have an avi without noise
now ,the wave you change as pal with belight
(or even with besweetgui)
then you mux those files
when your source ac3 audio is,you must demux in vdm (streamlist) an save the framerate of your ac3 file with ac3 machine
the
Prolem with 23.976 FPS AVI file
By ho1 in forum Video ConversionReplies: 3Last Post: 22nd Oct 2009, 12:50 -
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
How to stretch a DTS audio file from 23.976 to 25.000 fps?
By lorix in forum AudioReplies: 3Last Post: 10th Nov 2008, 14:55 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
Difference?? 23,976 pics/s or 29,976 fps
By twanbaten in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 12:29
