I have spent the last week finding out about creating a slide show to place on a DVD to view on a TV and its been a confusing time.
First I tried to use Serif PhotoPlus10 and then Serif AlbumPlus4 only to find that I could not place captions on individual slides.
I then tried Adobe Photoshop Elemnts2 and could not work out how use it.
Someone sugested Windows Movie Maker and then Windows PhotoStory which looked good but I could move neither to my DVD recorder viw Nero6 Recovered.
Over the next few days I had the following sugestions:
Pictureshow 2
Magix Photos
Pictures to EXE
Picasa2
Ulead Video Studio 9
ProShow Gold
Photodex, Pro Show Gold
Pinnacle Studio 9
Eventually I worked out how to use Nero6 Recovered to build a slide show with captions and burn it onto a DVD. Now to my question:
Is there a consensus on what the best software is to do what I want to?
the ones i have used are
Ulead Pictureshow
MemoriesonTV
ProShow Gold -
I have used memoriesonTV in the past, but mostly I use my editor (Vegas). Most competent editing software can load stills with a predefined length.
Read my blog here.
My favorite one of all time is Photo2DVD Studio . Pretty easy of use, and lets you create your own menu templates as your wish.
Commercial ware : Ulead picture it . dose a perfect job .
: Nerovision express , restrictive ... crap .
Freeware : Easyphototools
Just like dvdslideshowgui , only it work's .
As for dvdslideshowgui being a pain ... little or non existent support .. there is a method of creating 2 format's of slideshow's , but take's a little time and effort .
First format is an actual movie , play's from start to end .. easyphototool's will take care of that .
The second is more envolved , using the output of dvdslideshowgui , then passing all ouput picture's through dvdauthorgui , batch encoding of picture's to m2v's and basic authoring , followed by setting up time constraint's for each clip (picture) using pcgedit .
If you want it to be flash , you cant beat doing it the long way ... all other method's have restriction's .
Creating a Blu-Ray from TV Shows
By dbanimal in forum Video ConversionReplies: 10Last Post: 23rd Feb 2011, 14:31 -
Converting and placing multiple files on a DVD
By -phenom- in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2010, 15:27 -
High definition slide shows on DVD.
By EagleW in forum Newbie / General discussionsReplies: 13Last Post: 9th Jun 2010, 16:17 -
Best programs for .jpeg slide shows?
By Captain Satellite in forum Newbie / General discussionsReplies: 17Last Post: 30th Oct 2007, 10:50 -
Baffled!! Titlewriter shows nothing but DVD Player shows Movie Name
By Subhash in forum Authoring (DVD)Replies: 16Last Post: 25th May 2007, 13:02
