  1. I am after a program that will encode avi/divX/Xvid etc straight to DVD...in other words, straight to a VOB file. However, I need a program that will allow batch encoding & then be able to burn 5 or 6 files straight to DVD.
    I have used " DivX to DVD " ...great tool but does not allow batch session & you cant burn more than 1 VOB file to a DVD.
    Can someone please HELP ???
    Thanks,
    MLOR.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    In other words, you want something that encodes and authors in one. Unfortunately most avi/divX/Xvid etc that I've seen from downloaded sources tend to require a little more TLC than being thrown into an all-in-crap-one tool, but YMMV.
    It does. If you're talking about the old freeware version, hold Ctrl down and select multiple files. Make sure you select the file you want to be last first, and then go in order of playback from first to 2nd last (program bug). If you're talking about the new convertxtoDVD, it should be obvious how to add multiple files. Each file will be a seperate title.
    If in doubt, Google it.
