Over the past few years, my mp3 collecion has outgrown it's usefulness on the PC.
I now use my mobile phone as my mp3 player (Samsung A920), and there's no need for 192 and 256kbps mp3s, as sub-100kbps sound the same (to me anyhow).
I'd like to downsample my entire collection, and thus fit even more on the phone.
Anyone know of a batch prog that will do it?
I tried messing with CDEX, but can't grasp it's (supposed) ability to input multiple mp3's and output multiple, at a lower bitrate.
Results 1 to 9 of 9
Cheers, Jim
My DVDLab Guides -
Sonic Foundry Batch Converter.
Probably Sony Batch Converter now. -
Scmpx will do it in 2 steps using batch.
mp3 > wav
wav > mp3
http://www.din.or.jp/~ch3/index_e.html -
I'd also recommend dbpoweramp. Try to get version 9 as the newer versions may be trialware instead of freeware (not sure tho).
W -
The GodFather can do it too. It's also a great Tag editor and organizer. Freeware, just a Google away!
You can do multiple subfolders with dBpowerAMP by using "Search Subfolders" in Explorer. For example, search for *.mp3, select all, then right-click and "Convert to".Originally Posted by whitejremiah
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
How does my system downsample video data?
By mamoltub in forum Newbie / General discussionsReplies: 0Last Post: 25th Apr 2012, 07:37 -
Appending several hundred mpg2 clips
By schematic2 in forum EditingReplies: 1Last Post: 21st Dec 2010, 00:06 -
Lame MP3 (or any MP3) in Sony Vegas 7
By boom731209 in forum AudioReplies: 7Last Post: 28th Oct 2010, 17:13 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 05:36
