Hello there!
I have a problem which drives me crazy. I have been authoring a ~3,5 hour dvd with Nero (I first used tsunami-mpeg to compress the files), and I need the whole project to fit on a single disc.
Here is the thing: it all wotks nicely with pal, I can fit the project onto one single disc.
However, when I convert the vids to ntsc (again in Tsunami-mpeg) it seems impossible for nero to fit 4 GB onto a single disc.
I have tried with "Xdvd" format, I have tried compressing the vids to 3 GB (the quality is now very poor) but nero still won't give in.
What should I do?![]()
Help would be gratley appreciated!
/Kristofer
is the mpeg from tmpgenc 3gb?
and nerovision says that it wont fit? it probably wants to reencode so use something else to author with like tda. -
No, the video files all together make 3GB.Originally Posted by Baldrick
but are they in mpeg dvd format? then it shouldn't increase when you author.
or is it 3gb avi files? -
Yes they are mpg
I have tried both the DVD template and XDVD template in the Tsunami mpeg software. -
then try author to dvd-video with something else than nero. TMPGENC DVD AUTHOR!
EDIT2: Problem solved - bad media was the cause (Disregard the rest of this post)
Hi again!
I have tried authoring with software tsunami and it WORKED!!!
Then occurs the following problem:
Playback of the ntsc dvd disc is misbehaving on my main computer, after having watched a while and "surfed around" between the chapters the software (both nero and media player) crashes. This has never happened before.
I tried restarting the computer etc
I also tried with my laptop and it crashed when trying to shut down the dvdplayer software.
The disc is DVD-R "one-tech" . Burned at 6x speed.
EDIT: Now I have tried burning with "advanced analysis" in nero burning software with two different speeds AS WELL as
in TMPEG "writing tool" and still the same problem.
Someone please help!
/Kristofer
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
Missing Audio after DVD authoring using Nero Vision 10
By Deerkiller in forum Authoring (DVD)Replies: 0Last Post: 11th Sep 2011, 22:18 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
Blu-ray authoring with Nero?
By tomkat in forum Authoring (Blu-ray)Replies: 2Last Post: 4th Oct 2008, 18:48 -
Coming soon Nero 8 with HD-DVD and Blu-ray authoring
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 15th Sep 2007, 13:22
