Hi,
I have a file which is an Xvid .avi but also has the audio as MPEG-1 audio layer I.
I have tried to extract the .WAV from the file using VirtualDubMod, tried to convert to AC3; in fact tried to extract/convert the audio in a variety of ways but keep on coming up with the error "no audio decompressor could be found to decompress the source audio format".
This audio codec does seem very primitive but nevertheless is a mystery. The audio WILL play on my PC but I was hoping to convert it to play on a stand-alone DVD player with either AC3 or Lame MP3.
For the life of me I have searched high and low for any post relating to this.
Q: Which Codec do I need to allow me to decompress the ausio so as I may rewrite it as eithe MP3 or even AC3.
Any help appreciated...
Cheers,
Desmond.
Desmond Cassidy
Many thanks Baldrick...ffmpeggui seems to be doing the job...
SO I then use TmpgEnc to merge the AC3 track back in to either a VOB or a new AVI ?
Would it be possible therefore to install a codec to allow me to decompress on the fly in VirtualDubMod then ?
Cheers,
Desmond.Desmond Cassidy -
The Fraunhofer decoder that comes with windows should be able to decode mp1. Guess there could be some kind of header problem, like when it won't decode some mp3 streams in avi's even though it can obviously handle mp3.
If you wanted to set the video to direct streaming and the audio to full processing in VDub. ffmpeg or mencoder can do the same thing. -
Hi Celtic_Druid...
Yep...that's what I ended up doing...I used VirtualDubMod to DirectStream the Video and included/merged the newly created AC3 file from ffmpeg. AV Synchronization was very good using the Interleaved option with a 500 ms lead.
Interestingly enough, on a 1.8 GHz processor, an 850Mb avi, a 130Mb AC3 file, took about 5 minutes overall (including about 1 minute to load the AC3 file) to merge/create.
This coupled with potentially changing the FourCC code from XviD to ('divx, 'DX50') (2 seconds). The only potential delay in overall processing is the check for packed bitstream (using the MPEG4modifier tool) and unpacking if necessary - potentially an extra 7 minutes.
Many thanks to all who read, replied and took an interest - this forum definitely has the 'gurus' !!!
Cheers,
No audio decompressor could be found using VirtualDub
By dapster in forum Newbie / General discussionsReplies: 22Last Post: 6th Jun 2015, 04:25 -
VirtualDub - No audio decompressor could be found.
By kelemvor in forum Video ConversionReplies: 25Last Post: 24th Jan 2013, 16:36 -
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 14:03 -
No audio decompressor could be found to decompress the source audio format.
By rocky12 in forum AudioReplies: 3Last Post: 1st Sep 2008, 00:59 -
"No audio decompressor could be found..." in VirtualDubMod?
By Bix in forum Video ConversionReplies: 2Last Post: 6th Sep 2007, 16:18
