OK...another dumb question.
Can badly authored TDA folders result in a DVD that is proving
very difficult to burn properly and copy?
I'm stumped on this one. I'm getting bad burns on a DVD I created
yesterday via my DV Cam, TMPGEnc Plus 2.5 and TDA.
Inputted DV footage to Plus, encoded then authored with TDA. All supposedly went well but have yet to get a good burn from the folders.
The burns turn out fine according to the program but when I go to create
an ISO image of the DVD (my sister's player needs to have DVD+R's booked to DVD-ROM...and I only have DVDDecrypter to set booktype)...I'm getting read errors.
I even had a bad burn (read errors) on my TY discs.
I even tried folder2iso from the folders....same result.
I'm stumped.
I'm trying a simple single layer factory pressed DVD backup now with DVDFabDecrypter and my folder burning program (Prassi Ones) as a test to see if it is my BenQ1620Pro that is mucking up.
Simple backup also shows 3 bad "blocks" on Nero CD Speed.
I don't get it... -
I would use one of those cd/dvd cleaners on it. Have you updated the firmware? The last one is from 09/05. http://support.benq.com/front/BenqMain.asp?MenuHead=128&ShowType=program&FileURL=servi...otId=undefined
Hope this helps. I might be the burner is beginning to fail and time for a new one. -
They play fine....although one burn showed up as a data DVD...it would not play in PowerDVD.Originally Posted by mattso
I also have an old(er) LG4040B burner in this computer. I will try some burning with that one too. My BenQ is the one that can do bitsetting though...
...my LG cannot.
I wish I had written down all of the scenarios so far....but I didn't plan on having this much trouble. I have already disabled Skype and Skype Phone from my start up....that is the only thing I have really changed(added) on this computer recently....but my CPU usage was still at 1 to 4% even WITH the two Skype things active. -
I've already got B7W9(the latest) firmware on this one...which is rare for me cause I'm not a big firmware guy...Originally Posted by Bodyslide
I'll try my old faithful LG now.
Thanks Guys...I'll keep posting my mishaps...
Multisession DVD Burner and Burning Files into Specific Folders
By Disco Makberto in forum ComputerReplies: 9Last Post: 23rd Feb 2010, 02:48 -
Burning multiple remuxed folders to discs, playable as dvd
By blue2 in forum Authoring (DVD)Replies: 6Last Post: 8th Oct 2009, 10:05 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2007, 00:54 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 19:04 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
