I have two mpeg2 files that are two parts to a movie, when I use TMPGEnc DVD Author to combine them it says that the disk size will be exceeded. There are no menus, only chapter points... How do I make the size smaller so that it will fit on a dvd but not loose quality?
Hi tb582,
The easiest thing to do is to go ahead and author (ignore the error message) then shrink with something like DVD Shrink.
Quality is directly linked to filesize. Reducing the filesize WILL lose quality - you can't get away from that.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
how to shrink a 13gb mpeg2 to dvd compliant size
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 23rd Aug 2010, 07:53 -
How to shrink the file size of 7.63GB after ripping the DVD?
By coy228 in forum MacReplies: 6Last Post: 16th Jun 2009, 10:19 -
FFV1 does not shrink the DV size
By dywillnerd in forum Newbie / General discussionsReplies: 7Last Post: 1st May 2009, 22:59 -
Trying to shrink avi size, and more!
By janlafata in forum Video ConversionReplies: 8Last Post: 21st Dec 2008, 14:12 -
DVD shrink video size?
By chronic777 in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2008, 07:15
