i was going to burn an avi file when my dvdsanta started to frig up.
it does the "an error while trying to run, send report or dont send" thing.
So I asked my cousin what other program could burn it for me but he said to convert it to mpg and then burn it with nero? I downloaded a converter that if you only use the trial it puts a watermark in the middle of the video.
So my question is, Does anyone know another program that will burn my AVI for me? or a better converter to mpg?
Results 1 to 9 of 9
if you mean convert the avi to mpeg to be able to burn it to a blank dvd-r then yes.
That doesn't really answer the questionOriginally Posted by ouxch
Do you need it as an MPEG file burnt to disc (ie, your settop DVD player can play raw MPEG, or you're only gonna watch this on your PC), or do you need it to play on a settop DVD player (IFO, BUP and VOB files inside a VIDEO_TS folder) ?If in doubt, Google it. -
yeah that's the one i downloaded though and if you don't pay for it then they will put a watermark in the middle of the picture.
not the ooold version, http://freedownload.softonic.de/windows/vsoDivxToDVD_setup_0.52.99.exe
or just buy the new version. -
The old version has no watermark, and last time I tried the new trial version, the watermark was right up the top (semi-cut-off by overscan) so I don't know where you're getting "in the middle of the picture" from. Methinks you just read a webpage that mentioned a watermark and assumed without actually trying it ?Originally Posted by ouxchIf in doubt, Google it.
Noob convertion question
By Bob-bob-bob-bob in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jan 2012, 13:14 -
Noob HD/Bluray Question
By Startropic1 in forum Newbie / General discussionsReplies: 5Last Post: 16th Jun 2009, 16:04 -
noob question about muxing.
By Onime no Kyo in forum Newbie / General discussionsReplies: 6Last Post: 14th Jun 2009, 10:33 -
Which media is best for....(a noob question)
By reinstalled in forum MediaReplies: 5Last Post: 29th Nov 2008, 09:49 -
noob question...about VIRTUALDUB....
By SeeNoEVO in forum Video ConversionReplies: 1Last Post: 1st Jun 2007, 02:07
