I have tried winavividoeconvertor, convertXtodvd among others. Not happy with the results. The end results was that frames were jerky, audio out of synch etc.
What is the best software to convert AVI to DVD?
Many thanks in advance.
Results 1 to 14 of 14
width 640 pixels
Height 448 pixels
Video compression xvid
data 196 kbs
It is animation movie, spiderman from 1967 which kids like and I burn to a DVD as you can not buy this sort of stuff anymore.
Movie seems fine on a PC but jerky on a televisions set.
Meanwhile I will try DVD Santa.
Thanks. -
If it 29 even, then convertXtoDVD will be adding the extra .976 frames per second to get you up to NTSC framerate - you will see this in the log at the end of the encode "n extra frames were created". These will be duplicates of existing frames, and cause the jerkiness. PCs can playback any arbitrary framerate, and if there are enough frames per second, the results will be smooth. TVs and DVD are restricted to TV format framerates, so if your source framerate doesn't conform, extra frames will be created.
Basically it comes back to Baldrick's sage statement
downloaded crappy video often cause jerky playbackRead my blog here.
I tried another avi file. I tried VSO ConvetXtoDVD and Winavi Video Converter.
Winavi Video Converter gave same jerky results.
VSO converXtoDVD gave satisfactory results, nor jerkiness. Only one problem though, green block for a fraction of second in actions scenes. Is there is fix for this?
What other apps can I try? I am giving dvdsanta a try tonight. -
I have noticed the same blocks with three different source files. All corrupt? Unlikely. I guess I can not get perfect results.
Blocks when playing back from the HDD or the burned disc ?
I am always impressed by the faith people have in the quality of downloaded avi files created by someone with probably as little knowledge as themselves. I approach every avi on the basis that is has been created by people of dubious skill, using software of dubious origin, and downloaded across the internet - an incredibly unreliable and uncontrolled method of travel. That it is watchable is a minor miracle.Read my blog here.
If they play back without problem from the HDD then it isn't the encoder any more, it is either the media, the burning process, or your player and the media not getting on nicely. Don't waste you time with DVD Santa until you have confirmed this (personally, I wouldn't waste my time with it, period)
Read my blog here.
I had also tried DVD-R. I am certain it is not the burner as I don't have problems with my normal DVD to DVD burns. Only with this app on fast actions scenes for a split second only.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
