Im using EZDVDMaker from Avermedia.This product doesn't capture very well and and want to get a usb video capture device that will work with avs video capture can anybody recomend a usb capture device that will work with avs video capture?
I would recommend using firewire to capture, rather than usb. USB2.0 can work fine when capturing, but quite a few people have had problems when using USB. I don't know much about your AVERMedia software, but I haven't seen in mentioned much on these forums. Most all-in-one solutions don't work very well. I recommend that you look at some of the guides and tutorials here, and check out the Capture, Editing, and Authoring forums for good advice on free and/or inexpensive softwares which do a very good job.
Rob -
I need something that records in MPEG-4 on my laptop with composit inputs for my vcr.
Suggest searching the capture card forum, and use mpeg4 in your search criteria.
Rob -
Just an observation on USB-USB2 capture devices. There is no standard control protocol for USB capture devices. Each company develops its own drivers and software.
The device will be unsupported by all other software applications (e.g. editors, DVD authoring programs) unless specific drivers are developed for that specific USB device. Not many mainstream programs invest in non-standard driver development.
So, if you buy for example an AverMedia USB capture product, you are tied to AverMedia capture software.
The resulting MPeg2 or MPeg4 file can be imported into other programs.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Take a look at this product.
http://www.adstech.com/media/mediafiles/02-14ADS%20Shipping%20DVD%20Xpress%20DX2.docRob
photo capture from video signal hardware
By huegel in forum Capturing and VCRReplies: 0Last Post: 6th Mar 2012, 10:50 -
best capture hardware and best results for capturing video 8 and later VHS
By mayhampixi in forum Capturing and VCRReplies: 2Last Post: 4th Jun 2011, 22:51 -
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 02:02 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 20:18 -
Advice on High Res Video Capture Hardware
By Gregus in forum Capturing and VCRReplies: 3Last Post: 15th Jun 2007, 15:54
