    Jan 2006
    Canada
    i have movie which is bin/cue CD1 and bin/cue CD2 how can i joion them so it becomes one and then burn it to DVD
    It is in VCD or SVCD
    thank you very much
    USA
    I usually extract them with a program like ISOBuster to MPEG, then add them to a program like ConvertXToDVD and burn to DVD. That's an easy way. ConvertXToDVD has a freeware version available lower on the page.
    If they are SVCD, a program like SVCD2DVD may give better quality. Best quality would be using the individual tools for the conversion. The guides to the left would assist you in that. <<<<<<
  3. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    If they are VCD, then the video is already DVD compliant and you want to make sure that whatever tool you use, it doesn't re-encode it. Only the audio needs to be upsampled to 48khz.
    Buy My Books
