I think the Xvid/avi file is about 1000kpb , when i convert them to dvd files so i can watch on standalone..how much birate should i use to lose much quality?
Do I must use abou 4000kbs? the movie is about 3 hours long...Thanks, im using NERO
use a bitrate calc and figure out what the highest you can go is......if your aiming for a single layer disc, though, its gonna probably look a little rough on the quality end.........probably in this case, too, even if your aiming for a dual layer disc, just because 1000k/s doesnt generally make for the greatest source for a dvd conversion.....
its avi/xvid files...so i dont think i would need like 3000k birate , do i?
It doesn't matter if it's XVID or Divx, the main thing to concern yourself with is the length of the film. A 3 hour film will give you a constant bitrate of just over 3000. Encode a bit of the file and see if the quality suffices.
He's a liar and a murderer, and I say that with all due respect.
Whats the best Bluray to Avi/Xvid converter
By adamf154 in forum Blu-ray RippingReplies: 4Last Post: 23rd May 2010, 22:22 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
What's best to burn to DVD: XVID, DIVX, AVI?
By peterj in forum Authoring (DVD)Replies: 3Last Post: 17th Jan 2008, 08:35 -
whats the best dvd player for divx/xvid playback?
By saxon in forum DVD & Blu-ray PlayersReplies: 19Last Post: 19th Jul 2007, 12:55 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
