I had an AVI file that I converted to MPG using TMPGenc DVD Source Creator .. Now the subtitles (SRT) of the original AVI file won't sync with the new MPG file .. Now to create the DVD how do I sync the subs? Maybe they are elongated now!
Results 1 to 9 of 9
Usually, it's because the frame rate got changed, because SRT uses timestamp format.
Originally Posted by kschang
What framerate was the AVI, and what framerate was the MPEG? Find out if my guess is right!
Sure, that's one of the tools you can use. If I'm wrong, we'll try something else.
Do the subs gradually lose more and more sync, or is the missync constant?
You may be able to fix it with one of the sub editors in the tools section. -
OR can it be rectified at all??
Converted HD wmv to avi but won't get sound in media player device
By Moth Queen in forum Video ConversionReplies: 2Last Post: 20th Jul 2011, 17:24 -
DVD player won´t play converted .avi
By dexter30 in forum Video ConversionReplies: 4Last Post: 10th Dec 2010, 15:59 -
iTunes won't play converted files
By mez2 in forum ffmpegX general discussionReplies: 1Last Post: 12th Feb 2010, 12:50 -
VOB2MPG (converted MPG file has no audio!)
By sonicdeth in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 5th Jan 2010, 19:23 -
How to save converted *s2d.mpg in another folder???
By junkfood in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 15th Sep 2007, 10:01
