I have a Sandisk Cruzer mini 256MB memory stick, when i go to the option to safely remove it my internet connection is cut off at the same time.
Any thoughts?
“He who makes a beast of himself gets rid of the pain of being a man.”
Using usb modem? Probably down to low power from your usb ports
on your computer.
Usb was never designed to carry network transmissions hence intermittent disconnections and other problems.
Better off using an ethernet nic (network card) if you have one for your internet connection or if not get yourself a powered usb hub and connect everything to that. -
Thanks for the advice deckard8.
PEACE“He who makes a beast of himself gets rid of the pain of being a man.” -
Yes, a usb modem from BT. I can't find a way to fix the problem. I need my modem.
Yes, a usb modem from BT. I can't find a way to fix the problem. I need my modem and I don't want to pay for a powered usb hub.
Have you tried 2 things:
1. Go to the various site's - Motherboard and Modem - and see if there is a firmware (or patch) upgrade/update.
2. Do a google search to see if anyone has posted a solution elsewhere.
The hub - esp a powered hub - sounds like a good thing to try.
How do I get my PSP videos onto the memory stick?
By Prot in forum Portable VideoReplies: 5Last Post: 23rd Jan 2012, 12:32 -
Test the memory stick
By alintatoc in forum ComputerReplies: 2Last Post: 13th Jun 2011, 14:52 -
Internet Continously Disconnects
By imdaman in forum ComputerReplies: 13Last Post: 26th Mar 2010, 17:39 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 15:31 -
Memory stick?
By bevills1 in forum ComputerReplies: 2Last Post: 4th Jun 2007, 10:10
