when i join 2 avi together (typically w/ac3) w/nandub
the 2nd movie tend to be out of slightly out of sync
is there a extra steps that i can take to prevent this
or is there another tool i can use that is more reliable
I do it manually with a mix of virtualdub and avisynth, and don't have any problems
Read my blog here.
Hi-
Most likely the audio in part 1 ends before the video does. When you add part 2, the audio "slides" up against the end of the audio of part 1 and throws all the audio in part 2 off. You have to find out how much it's off.
Open the joined AVI in Media Player Classic and go to a place in part 2 where there's some close up dialog or a gun firing or something where you can judge the asynch. Pause it. Right-Click the screen and go Options->Audio Switcher->check Audio Time Shift. Estimate the delay (1000 ms=1 second) and if the sound plays before or after the lips move, or the door slams, or the gun fires. If you hear the gunshot after the gun fires, then you want to apply a negative delay. If the sound of the gun happens before the gun fires, then you apply a positive delay. Estimate that, OK it and resume playback. Adjust until you get it right. MPC makes real time adjustments. Once you have it, write down that delay (with positive or negative), uncheck that box and close MPC.
Open the part 2 AVI in Nandub, set preload and interleave for 96 ms (if AC3, not frames), and the delay for what you discovered in MPC. Set Video for Direct Stream Copy. Save it and give it a new name. Now the part 2 will be out of synch, but when joined to part 1, everything should be in synch.
joining mp4 files but audio out of sync
By Liselotte in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2011, 21:18 -
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 12:52 -
Edit Avi: VDub / VDubMod / Nandub
By Rinsin in forum EditingReplies: 11Last Post: 1st Mar 2010, 17:33 -
Audio out of sync (with over 0.5sec) when joining multiple avi files
By andy_blah in forum Video ConversionReplies: 28Last Post: 10th Aug 2008, 14:55 -
Audio Sync Problem Joining 2 AVI's Together from a 2 DVD Set
By boofer in forum EditingReplies: 6Last Post: 22nd Jul 2007, 01:29
