Hey, I've been reading up on how to convert HD Transport Streams to XviD and such, but i've hit a snag. The Sound is Skipping. The video I acquired came in 100MB parts, labled [FILENAME].0000.ts, ect. I used HDTV to MPEG2 1.11.83 to create one MPEG2 .MPG file. I opened that up in GDIndex and saved. The output .ac3 file had a delay, So i opened it up in DelayCut and fixed it. I opened the .d2v file GDIndex saved in VFAPICodec and saved the .avi so it could be opened in VirtualDubMod. I configured the settings for the XviD codec, added a resize filter to resize it to half the original resolution (1920x1080 to 960x544 -- is that resolution ok/valid?), Imported the fixed .ac3 stream and chopped a 5 minute section to test. I opened up the converted video, which looks great, but the sound is skipping a lot and not synched up with the video. Ok, the reason I posted every step I did is to make sure I'm doing everything correct. If i'm missing a step or doing something wrong please tell me.
Is the sound problem because I cut a piece of video and the audio couldn't be synched to the video? I dont want to take the time to convert the whole video if that's not the problem. Again, I'm very new at this so if there is an easier/better way to do this, please let me know.![]()
I appreciate it,
Mike
Why do you want it on xvid-HD?
The MPeg2_TS stream has been professionally produced and can't get better.
Are you just going for increased compression? The cost is extremely long processing times + the problems you mentioned.
Why do it?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 06:37 -
720p vs 1080i - which is best?
By snadge in forum DVB / IPTVReplies: 19Last Post: 31st Aug 2009, 19:19 -
1080i to what ??
By David97 in forum Video ConversionReplies: 3Last Post: 4th Dec 2007, 08:55 -
Convert 1080i .mpg to hr.hdtv (960x540 xvid)
By MrFingers in forum DVB / IPTVReplies: 4Last Post: 6th Aug 2007, 10:00 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / IPTVReplies: 27Last Post: 13th Jul 2007, 17:25
